Even though the o-ring looks fine, the sensor could still have gone bad...these items just break with time.
Jan
Boost Pressure Sensor
E170_Driver
- Year and Model: bye V70 2.4T, 2001
Former 2001 V70 2.4T owner
driver1234567890
- Year and Model: 1999
thanks for replying.
just want to make sue that the boost pressure sensor and the map are the same thing cause the error code po237 is for the boost pressure sensor. and my car is running fine it just has the checkengine light on. so would that closly relate to a sensor problem or somthing else. because i dont want to buy a sensor if i dont have too.
E170_Driver
That is correct, the boost pressure sensor is the MAP sensor, I spent $90 on the unit and the CEL light went off after I installed it. Word of advice, be very careful and patient when removing and installing the MAP sensor, the plastic clips holding it in place look very fragile. My symptoms with the P0237 error code was a rough engine idle during start up when the engine was cold, but then settled quickly after a few seconds.
Jan
Jan
driver1234567890
alright that would make sense mine would have a in and out idling too when cold.
driver1234567890
thanks for your help
E170_Driver
Any time and good luck...
Jan
Jan
andybbrown
- Year and Model: v70 1999
I need to know what the sensor on the left of the pipe is.
- Been thanked: 4071 times
That is the manifold temperature sensor on a ME7 (2001?) turbo car
- 8021 Views
Last post by adrian22
- 1290 Views
Last post by biohazrd76
- 4227 Views
Last post by precopster
- 41 Replies
- 10786 Views
Last post by EngineeringBloke
- 1506 Views
Last post by jimmy57
