My sons done it again, blew the air bag, (fell asleep),he is ok, 2nd time, found a doner, have to swap air bag, clock spring and drivers seat belt, there was no passenger in vehicle.
3 questions:
Does the control module have to be replaced or can it be reset?
Will the pass seat belt have to be replaced?
What years will fit a 93 940 non turbo?
Thanks,
Rick
1993 940 Air Bag Deployment, control module
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
1993 940 non turbo SRS lightanotherMattsDad wrote:Does the control module
Electrical: SRS Air Bag and Seatbelts
- 93Regina
billofdurham [MVS Moderator] said:bau321 wrote:Wish I knew.. wondering myself
1993+ 940s have an on-board diagnostic system for the Supplemental Restraint System that both monitors the system and stores any fault codes for later diagnosis. You can read and erase codes using the OBD box in the engine compartment.
Check out other URL: Electrical: SRS Air Bag and Seatbelts
anotherMattsDad
- Year and Model: 1993, 940
I finally have gotten the module p/n 0 285 001 042 (says 01) I'm assuming (there I go again), 1 air bag no pass bag,
Will a 0-285-001-040 (says 02) out of a 94 940 work since your only using 1 air bag.
Just for info, 1 person in vehicle, blew drivers airbag on impact (driver ok), minor damage to car, had to replace air bag. clock spring, both seat belts, and air bag module. All from the yard. Thank you (---- a p---)
For resetting the SRS module or reading codes see Bill Durhams earlier post in this forum
"1993 940 non turbo SRS light" or this from above:
Thanks again Bill
Thanks again Bill
- 93Regina
Stock Code 271740 ; 6812956anotherMattsDad wrote:Will a 0-285-001-040 (says 02) out of a 94 940 work since your only using 1 air bag.
Suppl. Restraint system (srs) 940 For vehicles without airbag on passenger side. For vehicles with airbag on the passenger side.
Volvo 940 1991, 1992, 1993, 1994, 1995, 1996, 1997, 1998
Volvo 940 SE 1991, 1992
Volvo 960 1991, 1992, 1993
- 1465 Views
Last post by JRL
- 1876 Views
Last post by otis44
- 1091 Views
Last post by packetfire
- 7295 Views
Last post by jimmy57
- 1426 Views
Last post by PapaNoni
