Hello guys,
My 1995 Volvo 850 GLT is throwing 2 codes P0131 (Sensor Circuit Low Voltage, Bank 1 Sensor 1) and P0137. It is also throwing P0300 P1310 P0301 P0303 P0304 and P0305, but I guess it is misfiring due to a bad fuel trimming or a bad response from O2 sensor. Engine is hard to start when cold and sometimes when hot.
Recent changes:
Front O2 sensor (universal)
Spark plugs (bosch)
Fuel filter, air filter
The engine only misfires when engine is completely warmed up (when driving for about 25 miles) or when there is more than 3 engine starts, also when hot.
My question is: How to solve that O2 sensor problem? (if it is the real problem)
I've done some reading with OBD, it follows below
1995 850 GLT O2 Sensor closed loop fault
- Year and Model: Many Volvos
- Been thanked: 76 times
Was the replacement universal oxygen sensor a Bosch? Anything but the OEM equivalent Bosch with the factory connector has historically been trouble but I think many of the problems with the Bosch universal have actually been in the spice box. Sensors other than Bosch have rarely, if ever, worked.
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
Misfiring is caused by a mixture issue, and o2 sensor merely responds to what it sees. I'd look at trims and go from there. Now if system doesnot stay in closed loop you may have a defective sensor. However, since car's hard to start I'd check ECT first.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
how can I look at trims? I dont know how to test the sensor in the car, to check its effectiveness.draser wrote:Misfiring is caused by a mixture issue, and o2 sensor merely responds to what it sees. I'd look at trims and go from there. Now if system doesnot stay in closed loop you may have a defective sensor. However, since car's hard to start I'd check ECT first.
draser
I'd use a scanner that can read live data, that will give you fuel trims, engine temperature and o2 operation. Also measure resistance of ECT when cold and hot.
So I did. Short term fuel trim locked on 0%. Long term fuel trim locked on 25%. Temperature is OK (90°). Idle MAF 5g/s (is that normal?). Idle throttle position sensor 12% (was not supposed to be 0%?)draser wrote:I'd use a scanner that can read live data, that will give you fuel trims, engine temperature and o2 operation. Also measure resistance of ECT when cold and hot.
ECT resistance: seems to be according with temperature.
Updates:
Did a research on PCV sistem, seems OK. Vapour still coming out from dipstick
Changed manifold gasket.
Cleaned EGR
Cleaned throttle body
- misha
- Has thanked: 155 times
- Been thanked: 432 times
That's a problem.moacyr wrote:Yes, it is a Bosch universal sensor.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
It isn't really a problem because it's universal Bosch sensor.The problem is laying in connection to original connector.It can't be soldered,it must be properly crimped and properly sealed.
Sensors can be made of Titanium and Zirconium.They are two different types of sensors.Titanium works in the way that it sends resistance value to ecu and zirconia one sends voltage.They are visually very different,especially the "head" of the sensor and the wires have different colors.
Our cars use Zirconia 02 sensor but there is just a small number of 850(s) which use Titania one.My guess is that those are the ones with Siemens management.They usually have Yazaki clusters.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 1770 Views
- 9 Replies
- 1569 Views
Last post by Steve in Beacon
- 994 Views
Last post by nico416
- 919 Views
- 2474 Views
Last post by TripleThreat719
