Hi,
I found out today that the back tires on this car are 195 60 R 15 and the front are 195 65 R 15. I had to wonder if that makes a difference with the speed sensor for the car and maybe the brakes too?
That means that the front tires sit up about 4.9 mm more than the back, flat ground to bottom of rim, and of course the rear tires turn a little more often than the front over distance.
1998 v70 Different Tire Sizes, OK or No?
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Put the higher profile on the back.It will look better...otherwise...no problem.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 311 times
- Been thanked: 817 times
You are correct about the speed sensor but it should be of basically no consequence for brakes or ABS.
The speedometer is set up for the front tires to be 195-60-15, so with those one the front it will be accurate.
The way you have it now, with the taller 195-65-15 on the front, the speedo reads a hair slow. When it says 65, you are actually going 67. The odometer clocks a little slow by the same percentage difference.
http://tire-size-conversion.com/speedom ... libration/ etc.
- misha
What about mine?It came from the factory with 16" Persus wheels and with 205/50/16 tyres.erikv11 wrote:The speedometer is set up for the front tires to be 195-60-15...
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
My guess is the speedos are all set up the same, but I do not know. If you check the online calculators you will see that those tires are almost exactly the same size (diameter is only 4 mm difference, whereas 195-65-15 vs. 195-60-15 is 20 mm difference).
So a 205-50-16 is running at 64.62 mph when the speedo (set up for 195-60-15) says 65.0 mph, I suspect Volvo just said don't worry about the 0.6% difference. For example, the car will have clocked 198,830 when the odometer reads 200,000, this is a tiny difference.
- Year and Model: Many Volvos
- Been thanked: 76 times
I haven't seen a specific trim stated bit if this is a AWD car then the tires must all be the same size, even tread wear differences can mess up the transfer case. On a FWD car I agree with the others, the car doesn't really care.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
I had a flat last weekend, and the donut spare on the front was setting off the traction control. Not a permanent-damage thing, but annoying.
If you have a limited-slip differential, you will drive it nuts by using two tires of different sizes. LSDs work to reduce the difference between wheel speeds (ie, to limit the slip). Putting a donut spare on a clutch-type LSD will wear it out right quick. I don't think any FWD P80 cars came with LSDs, though.
- MrAl
Hello again,
Thanks much for the good replies.
Sorry i forgot to mention this is a FWD and non turbo.
I will have to start including that info in the title with the year and model i guess.
So it sounds like it does not matter to any OBD2 detection sensors if the car is FWD, so that's good. I'd hate to have to mess with getting more tires at this point in time.
Thanks again.
Thanks again.
- 1757 Views
Last post by xiami
- 1947 Views
Last post by Sommerfeldt
- 649 Views
Last post by a3inverter
- 450 Views
- 685 Views
Last post by brando_calrissian
