1998 V90 How to fit rear mudflaps ?
This topic is in the MVS Volvo Repair Database » V90 Fitting Rear Mudflaps
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
martin calva wrote:9134616 and 9134617
There were different part numbers:
Mudflap 5DRS kit - 9134332
Mudflap 4DRS Kit 3529690
9134616 - 1998 Volvo S90 Base L6 2.9 Liter GAS engine.
See if your mudflap fits a S90
martin calva
Year and Model: V90 1998, 945 1995
Post by martin calva »
Thank you for the comments and questions.
My rear mudflap kit is part number 9134612 and the kit contains mudflaps 9134617 and 9134616 plus rivets and screws.
Volvo Part Warehouse says the kit fits the following:
Volvo 940 1994, 1995, 1996, 1997, 1998
Volvo 960 1994, 1995, 1996, 1997
Volvo S90 1997, 1998
Volvo V90 1997, 1998
I have verified it would correctly fit my 1995 940 wagon and a friend sent a photo of the same mudflap correctly mounted on a 1994 960 wagon as follows.
Mudflap 9134617 mounted on 1994  960 wagon
mudflap on 1994 960.jpg (44.38 KiB) Viewed 1836 times
Below is a photo of where the rear fender on my V90 where the mudflap should go. I hope the photo shows how the lining of the fender prevents the mudflap from being mounted. To mount the mudflap would need some significant cutting away of either the fender lining or of the mudflap.
Fender lining on 1998 V90 prevents mudflap from being fitted.
V90 lining obstrcts.jpg (53.91 KiB) Viewed 1836 times
I think my ideal solution is to find a Volvo datasheet explaining the modification needed or, failing that, a clear photo showing the mudflap mounted on a V90.
Thanks again for the help.
93Regina
Post by 93Regina »
martin calva wrote:My rear mudflap kit is part number 9134612...
Go to this Volvo Dealer's Site, and notice your part number above.
Scroll down the page to "Product Assemblies," then click on
Cover plates, air guides, mudflaps
and you will see, as shown in enclosed photo below (use horizontal scroll bar), Mudflap 5DRS kit - 9134332
There is a programming error....9134332 vs 9134612 are not the same, but on first page cited above, your number was there, but on second page cited above, my number was there.
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Volvo Parts Warehouse
www.volvopartswarehouse.com
shows the same part listing for mudflap kit 9134332;1394512
1988 Volvo 760 Turbo Wagon
martin calva
It seems that there were two different kits for rear mudflaps. My kit is numbered 9134612.
The number that you have found 9134332 seems to be a kit for 700/900 cars. Skandix http://www.skandix.de/en/spare-parts/bo ... t/1020846/ says:
applicable for:
Model
Volvo 740 restricted on: model years
Volvo 760 restricted on: model years
Volvo 940 5-Doors
Volvo 960 5-Doors restricted on: model years
ATTENTION: This part DOES NOT FIT to your selected car model: Volvo V90 (1998) 5-Doors B6304FS2 AW30-43
All the info I have seen so far indicates that my mudflaps are correct for the 1998 V90 (except for the little detail that they do not fit the car as it was manufactured).
martin calva
And looking on the Skandix site for 9134612 (my kit) it says:
applicable for:
Model Model year
Volvo S90, V90 all
This part fits to your selected car model, while there are no further restricting attributes listed: Volvo V90 (1998) 5-Doors B6304FS2 AW30-43
lummert
Post by lummert »
What would number 24 be used for (3538251)? It looks to be some type of spacer for the mudflap.
93Regina
Post by 93Regina »
martin calva wrote:It seems that there were two different kits for rear mudflaps. My kit is numbered 9134612.
Go to their homepage here, and fill in your vehicle information, then search for mudflaps.
It shows 9134332 is kit part number.
Otherwise, give your VIN to OEM Volvo dealer, and have them find the right part number.
As they note,
While every reasonable effort is made to ensure the accuracy of this data, we are not responsible for any errors or omissions contained on these pages.
Please verify any information in question with a sales representative.
martin calva
Evidently there are at least two different rear mudflap kits. The number that you have found 9134332 seems to be for older cars.
Volvo 940 5-Doors
My kit is 9134612 and is specified for S90 and V90. It seems that it will also fit all older 900's too.
When I found that it did not fit, my first reaction was that I had been given the wrong kit. But all the information I have seems to say that I have the right kit for my car. When the local garage owner told me he remembered that a modification was needed to fit mudflaps to a V90 that seemed to confirm it.
My kit was provided by a Volvo oem dealer who was given my car's VIN. When told there was a problem, the dealer double-checked and came back confirming that my kit is correct for my car.
93Regina
Post by 93Regina »
martin calva wrote:My kit was provided by a Volvo oem dealer....
I talked to a person with access to Volvo's bulletins, manuals, etc., and he could not find any specific install literature.
I showed at that OEM Volvo dealer's site how their website can show both part numbers...question is, does OEM Volvo have a problem with their part numbers?
I would have the Volvo OEM you bought it from to call Volvo's tech department. Was poster "lummert" correct that a missing piece is needed?
