Replaced ECT and T-stat. Went for 14 mile test drive. No CEL, no codes so far. Cooling fan did not run on after engine shut-off, although in fairness, it hasn't done that every time out.
I'm thinking, and hoping, that I've got this licked.
99 S70 Base - P0172, P0171 and P0174
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- E Showell
We'll we can rule out the ECT and thermostat. Turns out a 16 mile test drive would have been the ticket. Now I'll swap in a known good MAF and see how I do with that.
'95 855 auto (sold)
'95 855 auto (sold)
- Year and Model: Lots
- Been thanked: 128 times
I need to know if cooling fan stays on after shut down. All my cars have done this and I feel it's a normal function of the system if coolant temp is over a pre-determined value after shut down. It was designed to minimise coolant hot spots which may weaken the (plastic) radiator.
Did you try the battery reset?
- E Showell
Mike. Haven't done battery reset yet. That and swapping in known good MAF are next.
UPDATE -- can't swap in known good MAF. Attachment bolts stripped and can't get the good one out. Headed for the PNP on Tuesday to harvest a MAF or two along with other assorted goodies.
'95 855 auto (sold)
'95 855 auto (sold)
- Has thanked: 1613 times
- Been thanked: 4078 times
I'm pretty sure the MAF is an input only device ( that is, it just gives inputs to the ECU). I have no idea how a device that is input only can be taken out by the ETM. Sounds like the other guys need to back off the crack pipe....E Showell wrote:I was doing some reading on another Volvo forum -- I know, the shame -- and ran into a post by a guy who had ETM issues and theorized that a bad ETM can take down a good MAF and that, indeed, an otherwise good MAF would likely fail very shortly after the ETM failed.
- E Showell
I'be driven about a dozen miles since disconnecting both battery terminals and touching them together, then leaving the battery disconnected for a half hour. So far, no CEL and no codes pending. I'.'ve got about 100 miles to drive today. I''ll report back tonight.
'95 855 auto (sold)
'95 855 auto (sold)
Thats with the swapped MAF, right? Hope that nails it.
I just got my NY Inspection in the 100 miles between clearing the P1138 code, and the 50 miles I need to reset all the monitors. Its good to beat the man. Next time I win a slip and fall case, Ill spring for a new/used CVVT to put this one to bed. I cleaned it and it went from faulting right away, to going somewhere between 100-2000 miles before it faults. Maybe try cleaning one more time.
140 USD new
30-60 used
140 USD new
30-60 used
Same MAF is on the car. As far as I understand it's just a battery reset so far.
Steve this is a Denso MAF. There are no $140 ones unless you'd like to point me to that generous seller's link
- E Showell
Mike is correct. Just a battery reset so far. Drove c. 80+ miles yesterday and CEL is back. Haven't read codes yet, but I am betting PO172. I'll post after I read the codes later this morning.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
Latest code was P0455 gross evap system leak. I removed and retightened the gas cap and am assuming that may take care of it. Gas jockey was in a hurry at last fill up and I'm betting he did not secure the cap properly.
'95 855 auto (sold)
'95 855 auto (sold)
- 11141 Views
Last post by Turbo_Boss
- 728 Views
Last post by Jaz
- 10 Replies
- 8125 Views
Last post by pgill
- 2906 Views
Last post by Pretribrapper
- 5815 Views
Last post by matthew1
