1995 850 GLT O2 Sensor closed loop fault
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
moacyr wrote:Yes, it is a Bosch universal sensor.
Bosch P/N: 0 258 003 222
As according to Bosch Catalog
According to my o2 sensor catalogue,this numbers are matching with oem o2 sensor.Why did you wrote that it's universal?
It fits to 850 2.0 b5204s '91-'96
2.5 b5254s
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
moacyr
Year and Model: Volvo 850 1995
Post by moacyr »
2.5 b5254s
Because the connector is different. My older sensor's P/N was 0 258 003 593 (4 pin/1 connector), as the new one had 4 pin/2 connectors. So I cut the wires and used is as universal.
I have already done twice the connections. Problem remaining...
Besides, there is 2 white wires, and I was told by a mechanic that it does not matter the orientation on its connection. Is that correct?
misha
Post by misha »
The only problem with universal o2 sensors is connector.You can't just solder the wires to old connector.They need to be properly crimped and sealed.Sometimes,universal o2 sensors comes with splice box.
Those two white wires is heater circuit.You can connect them either way.Black is signal and grey is ground.
There was a few complaints about bad oem Bosch o2 sensors right from the box,so there is possibillity that yours was born bad.Bad thing is that you can't return it because you cut off it's connector.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
moacyr wrote:Besides, there is 2 white wires, and I was told by a mechanic that it does not matter the orientation on its connection. Is that correct?
It is, the white wires are for the heater and it doesn't care about polarity.
moacyr
Post by moacyr »
misha wrote:The only problem with universal o2 sensors is connector.You can't just solder the wires to old connector.They need to be properly crimped and sealed.Sometimes,universal o2 sensors comes with splice box.
The wires were not solded.
There is a possibility, unfortunately...
misha
Post by misha »
Did you crimped and seal them?I doubt that it had splicing box with it.Splicing box comes with universal ones and not always.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
draser
Year and Model: 2005 S60 2.5T
Post by draser »
Your high positive trim shows engine running lean and ECU adding fuel to compensate. Then there's the sensor question. I'd look at the sensor with the scanner, if it's stuck on low then it's bad. To check that just release some propane in the intake, carb cleaner, etc. If sensor signal goes high then it works. Should be a rapid change low to high.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
moacyr
Post by moacyr »
misha wrote:Did you crimped and seal them?I doubt that it had splicing box with it.Splicing box comes with universal ones and not always.
At first yes. Then I suspected there could be a connection problem, so I spliced the wires and made direct connection.
moacyr
Post by moacyr »
draser wrote:Your high positive trim shows engine running lean and ECU adding fuel to compensate. Then there's the sensor question. I'd look at the sensor with the scanner, if it's stuck on low then it's bad. To check that just release some propane in the intake, carb cleaner, etc. If sensor signal goes high then it works. Should be a rapid change low to high.
I'll try that. I managed to read the trims while driving:
When stepping on the gas, voltage drops to 0V. When pedal released, voltage rises to 0.9V. At this time the loop closes and there is adjustment by STFT. When pressing the pedal again, the loop opens and voltage drops to 0V. Then the STFT locks on 0%.
misha
Post by misha »
It's because ecu is programmed to totally ignore data from o2 sensors on hard accelerating(full throttle) and to use default values.The reason is that car always have it's maximum power when it needed and there is no risk that ecu will cut off fuel because o2 sensor reads too rich at the moment.
Btw...did you reset codes after o2 sensor replacement?'95 have built in diagnostic tool under the hood.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
