2000 volvo s70 non turbo car codes not being stored?
Hello everyone I am brand new to this site as I just purchased my volvo. The problem I am having is that when I had autozone hook my car to the scanner it powers up but says "this vehicle does not support live data" any thoughts or advice on this subject matter would be greatly appreciated. Robert
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Every obdII car supports live data.Scanner can be the one which don't support it.Maybe there is something wrong with your obdII connector or fuse.
Do you have check engine light on?Does the car have auto transmission?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Sometimes,when auto transmission set a code,it triggers check engine light and that code will not be visible on a regular engine code reader.Code is stored in tcm but that kind of code triggers check engine light.
Bad news are that you would need a special volvo scan tool for tcm codes or to visit a dealer.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Year and Model: Many Volvos
- Been thanked: 76 times
Yes, but the rub on VIDA/DICE is that it is a one trick pony. It will only work on a 99+ Volvo.volvo-85 wrote:Would dice vida work?
The clone units are cheap enough that it is worth the investment. For the typical cost of a single scan at the dealer you can buy your own. IF you happen to need a software download the unit will work but the VIDA subscription plus the software download makes it uneconomical unless you have a bunch of stuff to program. The bootleg VIDA doesn't talk to the Volvo servers to buy the software hence you need to subscription for programming purposes. The diagnostics do all work though so it is an important tool in the tool chest.
- 1705 Views
Last post by Kazthebassman
- 1461 Views
Last post by dikidera
- 88 Views
- 1761 Views
- 60 Replies
- 10859 Views
