Road Trip Preparation 98 XC
Ludermilch
Year and Model: 98V70XC 98V70R 01C70
Re: Road Trip Preparation 98 XC
Post by Ludermilch »
The position of renting a car instead of repairing/improving my own car is lost in me. The least expensive option in my neighborhood is a silly KIA Rio @ $54 a day. Plus it's a compact car, not suited to the true road trip I will be taking. Risks aside, I am excited to take my wagon on such a trip.
1998 V70XC
2001 C70
1998 V70R
2000 Subaru Outback VDC
Perception Fontana Tandem Kayak
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
You did all the big stuff it seems, just go and enjoy the trip. Take some photos when you see neat sites and post them in the "road trip" section 8)
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Road trip section? Wow, I've been using this site for years and did not know it had a road trip forum.
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
Sounds like you have prepped all you can. What else...Check tire pressure in spare? Make sure lug wrench is a usable one? (those L shaped ones are horrible).
I don't know if I would be driving around a spare fuel pump. These days, even with shipping, you can get anything delivered pretty much anywhere you break down. Extra weight adds up quick on a trip! I would personally remove the rear seats for weight reduction, and then pack heavier stuff low and middle of the car.
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
Been thanked: 472 times
Post by cn90 »
Let's see what can get you stranded and see if you can avoid it...
1. The 2 turbo coolant hoses. Glad you are replacing them.
I wrote the tricks in forum. Use Volvo OEM only. Do not use URO brand!
2. Go to local junk yard and pull: Cam sensor, Crank sensor and Ignition coil (this rarely goes bad, make sure you get the power stage too, part of ignition coil), and throw them in the trunk as spare.
3. Open the driver's side kick panel and inspect the heater core for any surprise.
4. Coolant Reservoir usually cracks at 120K. Best is to get new one: use Volvo OEM reservoir only.
The heater hoses that go from firewall to engine: after 150K miles, it is a guess. I wrote a DIY using generic Gates heater hose in forum.
5. Tstat: I use Wahler.
6. Bougicord $55.
7. Cap/rotor: Bosch only.
8. Spark plugs: I use NGK Iridium plug.
9. I assume the timing belt, rollers, WP are up-to-date.
10. Fuel pump: google Bosch 69693.
Have a good trip...
Ludermilch
After a visit to the pick-n-pull today, I walked away with the last of the emergency parts I needed. I also grabbed both front hard brake lines, a "Turbo" labeled air box cover from an 850, and an ECU to do some tuning with. :shock:
1998 V70XC
2001 C70
1998 V70R
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
Heater core hoses? Only thing that's failed on me (so far!) while driving.
Actually, before that, check your ball joints, control arm bushings, outer tie rods, tie rod boots, sway bar endlinks, and CV joint boots are also worth checking out. You can inspect them all in two minutes per side, and none of them is particularly hard to replace besides maybe the CV boots.
Get an alignment whether or not those parts need replacement.
Ludermilch
They appear fine (heater hoses). Are there symptoms common with failure? Alignment is upcoming after I replace the driver control arm, passenger sway link.
1998 V70XC
2001 C70
1998 V70R
j-dawg
Post by j-dawg »
Nothing specific, no. I guess you might see bulging or other signs of weakness, but they're just hoses.
Given that replacing those heater hoses often results in a dribble at the firewall fitting, it's probably best not to mess with it unless you think the hoses look like they're in bad shape. Maybe carry some 5/8" ID hose and a few extra clamps just in case. You can replace the hoses (and bypass the heater core) pretty easily by the side of the road if a hose bursts. (Mine were probably fine at ~245k; I replaced 'em because my heater core went and I figured I might as well do the hoses too.)
