1994 855T boost cutting in and out
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
1994 855T auto ---- I start it, let it warm up to normal, the drive it. After a couple of stop & starts, like backing onto the street, a traffic light or two, the boost goes away, like a switch was thrown. Up to that point, it works fine. I can drive it on the highway at say 60mph and there will be no boost, but I can feel it trying to come on, sort of like a stutter. I almost feels like a loose wire making intermittent contact..If i floor it, get the RPM's up to 4K or so a couple of times, then come to a stop, the next time I push the pedal, the boost is back. And generally, it will stay that way, working fine. I am getting a front knock sensor ODB code, but I am not sure if one has anything to do with the other. So, could it be a stuck wastegate?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- Has thanked: 2866 times
- Been thanked: 1332 times
Sounds like a collapsing intercooler/throttle body hose. Or a half-blown off hose.
azureblue
I'll look for that, but it sure acts like a bad electrical connector or stuck BOV...
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- Has thanked: 2215 times
- Been thanked: 1853 times
Try replacing the TCV. Sounds like it is failing. Also check the pipes to it for cracks.
As Matthew suggested, also check the hoses and intercooler for cracks.
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
I had a similar situation, turned out to be a collapsing intake hose. Only Volvo made that particular hose at the time, and it was priced accordingly. I suspect a hose collapse or a leak.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
azureblue
There is a well stocked parts yard nearby, so I'm going to get the valve and maybe hoses, and the Intercooler hoses as well. It sure acts like that valve is sticking.
The yard has 850's, 70's, 60's and maybe an 80 - are the valves all the same?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- pkc303
I'm not sure if they are the same.
My problem was the intake hose after the intercooler. It collapsed under high suction, but not at idle. It had a lot of oil on it, and I guess got weakened.
TCV is Turbo Control Valve. It has 3 pipes running to it and typically mounts on the air intake box on turbo S/V70's. Having had a look at 850 parts drawings, it may be called a Pressure regulator part # 1271630. Fitted to 850 turbos from 94-97, it looks like it does the same job as the TCV. IT regulated turbo boost pressure. The valves stick or seize limiting turbo boost.
- 360 Views
Last post by azureblue
- 1022 Views
- 12 Replies
- 2912 Views
Last post by ferocity02
- 1925 Views
Last post by ElVee
- 692 Views
Last post by jreed
