POLL What octane gas is everyone using?
What octane gas are you using? (US... vs. RON)
<= 84. If you're outside US/Canada -> 88 RON NON-US
0
No votes
85. If you're outside US/Canada -> 89 RON NON-US
0
No votes
86. If you're outside US/Canada -> 90 RON NON-US
0
No votes
87. If you're outside US/Canada -> 91 RON NON-US
8
24%
88. If you're outside US/Canada -> 92 RON NON-US
0
No votes
89. If you're outside US/Canada -> 93 RON NON-US
3
9%
90. If you're outside US/Canada -> 94 RON NON-US
1
3%
91. If you're outside US/Canada -> 95 RON NON-US
10
30%
92. If you're outside US/Canada -> 97 RON NON-US
1
3%
93. If you're outside US/Canada -> 98 RON NON-US
10
30%
94. If you're outside US/Canada -> 99 RON NON-US
0
No votes
=> 95. If you're outside US/Canada -> 100+ RON NON-US
0
No votes
Total votes: 33
chrisjm91
Year and Model: 95 Volvo 850T5
Post by chrisjm91 »
Please, if you're outside Canada, the United States, and Brazil, vote for the RON value(s) you use - the number to the right.
I drive a 95 850 turbo with about 100k miles on it and just recently switched to 93 after reading up on octanes. I have to say I've noticed a little bit smoother engine. Just wondering if I'm crazy or if other volvo enthusiasts are running 93 octane in the turbo models volvos, as well as N/A.......
Has thanked: 311 times
Been thanked: 817 times
I run the standard high octane in my turbos (that's 92 around here) and 89 in the NAs.
Has thanked: 2205 times
Been thanked: 1852 times
Called premium here in Canada and is 91/92 octane. I use this on Volvo turbos. On the 850NA I used 87 octane around town (Regular gas), but 91 for highway.
taxi
Year and Model: V70 2000
Post by taxi »
I use 98 octane, it's either that or 95. Maybe that's one of the reasons fuel is so expensive here :D
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Definitely no pinging noises on our 95 or 98 octane fuel in our turbo XC 2002. There's another story when running 91 or 94 octane with 10% ethanol in the same car.
Haven't noticed any difference in my 2000 V70 NA between fuels as I don't think that the fuel management system yields any more power or economy with better fuels.
draser
Year and Model: 2005 S60 2.5T
Post by draser »
It seems that the base gas coming from refineries is the same, then it gets anti knock and other additives that actually makes the 85, 87 and 92 octanes. The caloric power, or BTU is the same, hence no actual difference felt in NA engines. Curious though, why in a LP turbo that has a base CR of 8.6 :1 we still need to use premium gas? How much higher does compression get due to turbo?
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
taxi
Post by taxi »
O don't know why, but doesn't turbo engines have less compression?
Been thanked: 4071 times
My 1999 T5 is 8.5:1 compression ratio - I use regular gas in that, as I stay off the boost. In summer, when I tow boats, I go to 93
My 2005 is 10.5 compression ratio NA and gets 93 year round.
Turbos have lower compression so they don't blow up...
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
I use premium bmb 95 all the time.
In the past...it was just bmb 95.
We don't have lower octane fuel than 95 on gas stations here in Serbia.
When i was a kid there was regular,super 95 & 98 and unleaded petrol available on all gas stations.
Now....super and regular are forbidden by our "gouverment" laws and there is only BMB (unleaded) available in 95 & 98 octanes.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
mnorris23
Year and Model: 2000 S70 2.4l GLT
Post by mnorris23 »
chrisjm91 wrote:I drive a 95 850 turbo with about 100k miles on it and just recently switched to 93 after reading up on octanes. I have to say I've noticed a little bit smoother engine. Just wondering if I'm crazy or if other volvo enthusiasts are running 93 octane in the turbo models volvos, as well as N/A.......
I ran 93 for a week in my s70 (turbo) and it did seem smoother. Being young and working a minimum wage job I had to drop back to unleaded because I couldn't afford it.
Car I own: 2000 Volvo S70 GLT 130k Stock with OEM replaced parts.
