1994 940 Air conditioning ports
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Evacuate, evacuate...as they say, you need a vacuum pump to evacuate your AC system in order to charge it.sickboy wrote:I went to vacuum my a/c system..
Going down to the car wash, and using their vacuum cleaners will not work.
Yes, by hooking up the low side, and letting it evacuate for about 30 minutes, this should work fine.
Before adding refrigerant, let it sit for ten minutes with vacuum-pump line turned off. Bled off air before allowing refrigerant into your system.
