'99 S70 Base -- Need Procedure for Removing Shift Lever
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Title says it all. I have the opportunity to acquire woodgrain trim for the S70, including the shift knob. Since the shift lever base on my car is damaged, I'd like to remove the entire shift lever mechanism and replace. Does anybody have a breakdown of the necessary steps? Thanks.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
JRL
- Year and Model: Several
- Been thanked: 16 times
Once you remove the console it will all be right in front of you and fairly obvious.
- E Showell
Jim -- No tricky connections between any cables and lever mechanism? Is this a ten minute swap, or am I looking at a more involved project? Thanks.
'95 855 auto (sold)
'95 855 auto (sold)
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
The shift lever base is secured with two clips in the rear of the base, then the base is pivoted forward. Base removal is a 2 minute job if that. Be aware of the light bulb assembly. Leather boot un clips.
- E Showell
But I want to bring the lever and base out as a unit. Is that still the ticket, or do I have to detach a cable from the lever somehow?
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
Perhaps I am making an erroneous assumption. I want to replace a cracked shift lever base and I want to swap out a plastic shift knob for a wood grained one. I assumed that was most easily done by switching out the entire lever mechanism. Am I wrong about that? I could just swap the knob and base and leave the lever alone. Thoughts?
'95 855 auto (sold)
'95 855 auto (sold)
JRL
Is this a stick or auto?
- E Showell
Auto
'95 855 auto (sold)
'95 855 auto (sold)
- 1692 Views
Last post by paredown
- 797 Views
Last post by Mr. Weekend
- 925 Views
Last post by mrscullini
- 826 Views
Last post by MoVolvos
- 14 Replies
- 3945 Views
Last post by estrekal
