Glad Misha got you pointed in the right direction after I miss-understood the issue. Great call, and that crank mount is a common failure, as oil always seems to get on it from somewhere!
1996 850R Wagon - strange vibration while in reverse
- Has thanked: 2207 times
dmack87
- Year and Model: 1996 850R Wagon
It was leaking oil that killed it, and even after doing the PCV I still have a leak. I'm afraid I let the PCV go too long now I am faced with figuring out where the leak is coming from and fixing it. It never ends!
- misha
- Has thanked: 155 times
- Been thanked: 432 times
There are no rules...i had no oil leaks onto it.After 17 years of doing it's job...it doesn't matter.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
If you still have leaks on the front of the engine in the cam belt area, the usual culprits are the main front crank seal, or oil pump seal, and the cam seals. By removing the timing belt plastic cover, it may give you a better idea. Take some photos if you can, and we can try to help pinpoint the culprit!
dmack87
Neil, I started a new post on the oil leak with pictures. If you want to take a look, I would appreciate it!
https://www.matthewsvolvosite.com/forums ... =1&t=70177
Experiencing similar issue on a 1996 Volvo 850 GLT Wagon. Ordered the Passenger lower right mount that bolts onto cradle with (2) 17mm bolts and to motor with (2) 14mm bolts. I changed mount, but vibration in reverse still present. I have to change my top mount as it moved over to passenger side. Is there any other mount locations or issues that will cause this vibration?
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Having just replaced the mounts on my 96 a couple of days ago, I can only give you my take those. I would think the mount by the crank pulley would be most likely to cause vibration. More potential for metal to metal contact. The two others are big hydraulic mounts, one back near your exhaust and the other near the dipstick. There is also a transmission torque rod, but I can't see that causing vibrations at low speed in reverse. I guess if it's really shot. Maybe as mentioned in this thread you have a brake issue of some sort.
All I got ...
All I got ...
1999 V70 GLT
1999 V70 GLT
