Would Vida Dice show cam sensor data issues or similar?
My 200K mile 2001 has little to no boost. It feels like it's there at low RPM and I swear I hear it spooling but anything over 2K RMP is spineless like I'm running a 3 cylinder...even jerks a bit in 3-4K range. Figured it might be a TPV but haven't found time to swap one to figure out.
It's been suggested a couple times that timing may have jumped a tooth but I would assume that would throw some codes...which I have none other then a bad o2 sensor.
Any easy way to tell? IS there a tell tale sign?
2001V70T5: How to know if your timing jumped a tooth?
carboncow
- Year and Model: 2003 XC70 2018 S60
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
JRL
- Year and Model: Several
- Been thanked: 16 times
Jumping one tooth hardly makes a difference. It will throw a code in a 100 miles or so
Jump more than say 2 or 3 and you won't run
Something else is going on, at those miles you may have lost a cylinder
carboncow
I can do a compression test this weekend to rule that out.
Are these symptoms comparable to a no functionality TCV?
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
- Been thanked: 4071 times
Just try unplugging the TCV to see if you notice a difference to diagnose
carboncow
Tried that already and unplugging it had no impact on the lack of power. It there a code of course and when reset nothing improved.
If I get time this am I hope to do a quick compression test.
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
- 3058 Views
Last post by erikv11
- 12 Replies
- 7141 Views
Last post by oragex
- 4930 Views
Last post by misha
- 9424 Views
- 1134 Views
Last post by Cees Klumper
