'99 S70 Base -- Need Procedure for Removing Shift Lever
Has thanked: 2200 times
Been thanked: 1852 times
Hi Evan,
If I understand what you want to do is remove the whole assembly and want to know how to disconnect the cable from the shifter assembly. Do you need the whole assembly or do you just need the lower part that kahl shows in his picture.
If you just want the part he is showing, and have already undone/removed the center console, then the guys have explained how to get just that part, although if you want the gaiter also, you need to remove the shifter knob first. To do this, twist the top of the gaiter around the shifter shaft about 45 degrees, then pull the gaiter down as it should have released the gaiter from the shifter shaft.
To remove the shifter knob, you need to pull hard and straight up. It will suddenly give, so be ready.
If you need the whole assembly, then I can't help just now as I don't have access to Vida currently. Perhaps someone else can jump in please?
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Thanks, Neil. I don't need the whole shift lever assembly. I had erroneously assumed it would be simpler to get the shift knob by simply removing the lever. Mo need to put myself through that. Just looking for the shifter knob and surround that Kahl has written about and with the various responses, I believe I now know what I need to do. Thanks to all.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hi ES,
Does it look anything like this:
Gear Shifter, s70, 1999
E Showell
Post by E Showell »
Nope. That's for a stick. I'm working on an automatic transmission.
'95 855 auto (sold)
MrAl
Post by MrAl »
Hi,
Ok, couldnt find anything for an automatic, sorry.
