2004 Volvo XC90 Transmission Oil Leak
netasp
Year and Model: XC90 2004
Post by netasp »
do you add oil from the same location as where the trans dipstick comes out? or is there another place where you add oil to?
I will buy oil with one of these brands:
mobil 3309 or Toyota T-IV or
Ford as well. Their # is XT8QAW
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Yep through the dipstick hole. DO NOT remove any bolts on top of transmission.
Get a narrow long funnel or use plastic tubing.
netasp
Post by netasp »
Thank you!
Ou2mame
Year and Model: 2004 xc90
Post by Ou2mame »
Mine leaks a tiny bit. I'm not too worried. At 145k I expect it to. It's not a big deal.
netasp
Post by netasp »
Its actually funny, I started to checkout every XC90 on the street and most are leaking from the same spot..lol
I think mine is leaking from the Transmission Oil Pan Gasket, and if this is the case it should be an OK job. I tried to check the transmission oil level myself without removing any hoses but it was impossible.
The only annoying issues is I have to take it to a garage to check the oil level for me, and the worrying of taking the car for a long trip...
netasp
Post by netasp »
I turns out the driver side Axle seal was leaking and not the transmission.
very happy :D
Been thanked: 504 times
Post by cn90 »
That is what I thought too.
It is extremely unusually for the ATF to leak through the gasket between the 2 halves of the transmission. This may happen at 300K miles +, but not at your mileage.
Axle seal is easy, just remove the axle, then replace the seal using appropriate socket.
The Volvo seal is made by CORTECO if you want to save money.
I use rmeuropean dot com.
Procedure to add ATF is below.
DIY: 2005 Volvo XC90 2.5T: ATF, Angle Gear, AOC/RDiff Fluid:
https://www.matthewsvolvosite.com/forums ... 10&t=64335
netasp
Post by netasp »
I took it to a Volvo mechanic and he used the original OEM part as I don't have the tools to do it myself.
Thank you very much for your help.
gstallons
Year and Model: 2004 XC90
Post by gstallons »
You can purchase a dye to add to the fluid to see where the leak is. You use a UV lamp to find the leak after a few days . This will show up in a high-vis green color.
