2008 XC90 Overheated, No fan
ingydrummer
- Year and Model: 1996 960 2002 s80
So my XC90 overheated yesterday didn't know why so I went through some test's. When I turn on the a/c the fan did not work. I pulled the plug and there is power to the red wire on the plug and when I plugged it back in the fan came on. Drove it around town for a little and when I got back to my garage the fan is still running. I shut the motor down and restarted it and again no fan? I pulled the plug to the fan and put 12 volts and a ground directly to the fan and I get nothing. Would this indicate that the fan is shot or could it be something else? Thanks for any suggestions.....
1996 960 2.9
2002 S80 2.9 FWD
2008 XC90 3.2 AWD
2010 XC60 T6 AWD
2002 S80 2.9 FWD
2008 XC90 3.2 AWD
2010 XC60 T6 AWD
all those fans have a module on them that is probably gone bad, I think you can replace just the module but have not done it my self, best option is to replace the fan motor and module at the same time, try ebay for used items and a new one will be expensive
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Check the violet (I think is violet, the single small gauge wire) plugged into the fan unit. That is the control signal. As mentioned the fan has an integral module that regulates current for the motor for variable speeds.
ingydrummer
I will check and see if that tiny wire is bad, I though be putting a hot and ground on the plug directly from the battery would fire the fan up but I must be wrong. Thanks you guys
1996 960 2.9
2002 S80 2.9 FWD
2008 XC90 3.2 AWD
2010 XC60 T6 AWD
2002 S80 2.9 FWD
2008 XC90 3.2 AWD
2010 XC60 T6 AWD
- 715 Views
Last post by SuperHerman
- 977 Views
Last post by xHeart
- 1311 Views
Last post by DougM
- 10 Replies
- 3371 Views
Last post by oorhett
- 37 Replies
- 6757 Views
Last post by erikv11
