2004 XC70 A/C Quits Cooling
Local Boy
Year and Model: XC70 2004
Post by Local Boy »
AC will occasionally (once or twice per week) not cool if the car was turned off with AC running. Pulling fuse for ECM resets the problem. The AC doesn't fail while car is running, or when AC was turned off prior to turning the car off. Any ideas?
Has thanked: 1609 times
Been thanked: 4065 times
That's an odd one. It does sound like the control unit needs rebooting. There isn't much you can do without software on P2s, though.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
If you have (access to) a VIDA/DiCE setup, you want to look for CCM-related or other modules' COMM Fault codes that may cause the CCM to get kicked out of line.
Also, look for ripple in your supply voltage to the CCM (with the engine running), the problem could be simply noise (EMI), I am thinking a bad main filter cap, or the alt, or simply a broken/loose ground somewhere... 8)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
Local Boy
Post by Local Boy »
Thanks for the responses!
I was thinking of a pressure or temperature issue (or bad sensor) that occurs when the car is turned off and the AC system is in operating mode??
regent
Post by regent »
That could be, too.
But I strongly recommend reading the car for codes as a less costly approach before your start throwing parts at her (unless you have an 'inventory' car in your garage to borrow parts from... :lol:
2015 BMW 335i
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Just to make sure, the gap at the A/C clutch is withing the specs?
