1998 v70 Obtain Those Little Rubber Vacuum Elbows
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hi,
Anyone know where to get these things? I ordered a couple on line but they turned out to be a little too big. The vacuum lines are a little smaller than the elbow inside diameters. I know i can rig it up somehow, but i would much more like to get the right elbows as they are not that expensive i bet. These were cheap too, about 1 dollar each.
Thanks much...
Been thanked: 504 times
Post by cn90 »
Just use some generic vacuum line.
MrAl
Post by MrAl »
Hi,
That's an interesting idea, and i think that would work for some connections. However, two that i'd like to replace happen to come out of the back of the air cleaner compartment and make a sharp right bend, toward the center of the engine compartment, and there's little room for a wide bend that would not kink the hose.
Also, one of the vacuum lines is much thinner than the rest, im not sure why, but its' like less than 1/8 inch or something while the others are a little wider. Not sure why they would do that but it's a thinner line that needs an elbow too. The other line is wider like the rest, which might work ok.
I was just hoping to get a part number or something to look up on the web and order a couple that would fit naturally.
Any possibility of that?
rwmm415
Year and Model: V70, 98
Post by rwmm415 »
I find that places like Kragen and Autozone now carry small packages of generic auto parts like nylon door panel fasteners and vacuum connectors. I bought a package of elbows (6-8 of various sizes, IIRC) at Autozone last year. Sorry I don't have the package any more or I'd send you the SKU. So all I can say is check your local parts superstore and see if you find a section of small generic parts like this. Good luck.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Al -- My local Advance Auto -- On Route 46 in Hackettstown -- carries a generic Dorman brand 90 degree vacuum elbow that works for that location. We can make a run up there when you come to observe the suspension work if you'd like.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
MrAl
Post by MrAl »
Hi,
Thanks rwmm, i'll check that right away.
Thanks ES, we have an AutoZone right in town now (i think 1 mile away or even a little less ! where Thule used to be) but if they dont have one i'll check Advance, and yes thanks, if i dont find it i'll wait till fix it day then and i guess we can both go. Thanks for that too.
Funny how these little things become more important when they break off. One was dry rotted i guess and broke into pieces.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I had the 'crumbly elbow' syndrome on my '97 855 GLT a few years back and bought some aftermarket replacement elbows which quickly crumbled again. Then someone on MVS told me to try thick wall silicone tubing instead. The thick wall allows you to bend the tubing 90 degrees or so without collapsing or kinking. I've been using it for about 8 years and it works great.
MrAl
Post by MrAl »
Hi,
Sounds interesting, but where do you get the thick wall silicon tubing?
One of my elbows actually as a 1/16 inch inside diameter hole to accommodate a 1/16 inch vacuum line ! I didnt know they made vacuum lines that thin.
That's very small, while the others are more standard like 1/8 inch inside diameter.
E Showell
Post by E Showell »
I don't know about the silicone hoses, but I just keep a few of the generic ones "in inventory."
'95 855 auto (sold)
Has thanked: 311 times
Been thanked: 817 times
cn90 wrote:Just use some generic vacuum line.
MrAl wrote:... That's an interesting idea, and i think that would work for some connections. However, two that i'd like to replace happen to come out of the back of the air cleaner compartment and make a sharp right bend, toward the center of the engine compartment, and there's little room for a wide bend that would not kink the hose. ...
The idea with generic vacuum line is to replace the whole line, elbow, hard plastic and all, not just the elbow. That way there is plenty of room for bends. It's much simpler that fiddling about with specific elbows, and a quality, thick-walled rubber vacuum line will be cheap and last several years. The hard plastic lines you are connecting the elbows to are 20 years old, they are due for cracks now too, I like to just get rid of them. Thick-walled silicone can be used the same way, either can be had at most parts stores or if your local ones don't have the silicone you can order it online from lots of vendors. Stick to the thick-walled stuff.
