'96 855 Tie Rod end stuck in steering knuckle--MVSolved
dosbricks
Been thanked: 4 times
Post by dosbricks »
I'm using a tie-rod pickle-fork tool but have pounded it nearly to smithereens. It's been soaking in PB-Blaster for 24hrs, and today after removing all remnants of the rubber boot, I resorted to heating the knuckle with a torch and pounding with a 6lb sledge. Also applied PB-B right after heating. No joy. :cry:
I'm concerned all this shock may be transferring to the steering rack and might damage the seal.
I would appreciate advice from the battle tested wing of this board. Thanks.
harryhendo
Year and Model: 940, 855, S70, V70
Post by harryhendo »
First, I'm assuming you removed the tie rod end nut holding the tie rod to the steering knuckle, then replaced it a few turns to hold it steady.
The best method I've found is to use a balljoint separator tool, like this one, instead of a pickle fork:
https://www.amazon.com/OTC-6297-Ball-Joi ... 716&sr=1-3
This tool pulls up the top end while also applying pressure on the bolt. It works very well.
'92 940
'94 855 (manual!)
'00 S70 (manual, the $500 experiment)
'02 V70
Been thanked: 504 times
Post by cn90 »
Or place a piece of wood to support the steering knuckle and hit the tierod end from above ---> downward.
dosbricks
Post by dosbricks »
A big tip of the hat and thanks, harryhendo, for pointing me to the right tool. I made a run to Harbor Freight and got this with a 20% off coupon:
http://www.harborfreight.com/3-4-quarte ... 99849.html
It actually has the same type bolt head on the screw part as the one on Amazon.
It worked and when it popped loose like a shot, I knew that pounding that pickle fork separator would have never done it. Some of these are a bear to deal with, and now having the right tool will make this job cake in the future.
Cheers
Has thanked: 1611 times
Been thanked: 4072 times
We heard the pop up here in NY!
Bravo Zulu!
dosbricks
Post by dosbricks »
South Jersey....maybe :P
harryhendo
Glad it worked for you Dos Bricks! It is quite a thrill when that tie rod end pops out. My son and I are rebuilding his recently acquired '94 manual trans 855, so listen for the pops later this summer ;-)!
'92 940
'94 855 (manual!)
'02 V70
