96 850 GLT What does this air cleaner hole go to?
crisnumbertwo
Year and Model: 1996 850 GLT
Post by crisnumbertwo »
Hello all,
I just got this new air cleaner box, because the air intake with the flap was busted off when I bought it. My question is, what does that threaded port go to, connected to the air intake port with the flap?
Thanks in advance!
Has thanked: 2199 times
Been thanked: 1852 times
If your car is a non-turbo, then the left pipe as seen in your picture has a length of corrugated aluminum tube running to a heat shield above the exhaust. This is for warming the engine quicker in cold weather. The hose on the right in the picture should have a length of plastic pipe running up to the LH side of the radiator with an oval connector that runs down in-front of the radiator to draw in cool air for the air intake.
93 850 GLT engine bay
At the front right of the picture, there is a pipe running between the battery and radiator. That is the cold air intake for the engine. Unfortunately the warm air feed is hidden down the back of the engine and connects to a heat shield near the middle of the rear of the engine on the exhaust manifold.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
There is a wax capsule thermostat that controls that flap and when it goes bad the flap gets stuck on the hot air side. It kills the performance and the fuel economy when that happens. On my N/A cars I just forced the flap to the cold air side permanently.
crisnumbertwo
Thank you, Neil and Lee, I appreciate your time and insights! EDIT: So I can just cap it, or leave in open, given warm weather?
Post by Ozark Lee »
Leaving it open is preferable. If you cap it the car can't get any air when the damper is to the hot side. It all gets filtered the same.
crisnumbertwo
Thanks again, Lee.
I hope, one day, to be as helpful as you guys.
