850 turbo not cranking over
Broken850
Year and Model: 1995 850
Post by Broken850 »
Hello,
Just had an issue that left me stranded. In the morning, she fired right up no problem. After work I tried to start as usual and the starter wouldn't react to the key switch. At the same time all the doors lock. If I try several times, a light smoke comes from the steering column. Battery is good, and jump starting doesn't change a thing. I'm thinking starter, but was hoping someone out there had a similar experience with the doors locking every time a start was attempted. Thanks in advance!
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Sounds like you shorted a wire and caused smoke.
85 GLH, 367 whp
00 Insight, 72 mpg
draser
Year and Model: 2005 S60 2.5T
Post by draser »
Is there an immobilizer in these cars, in ign. sw. area? I'd remove column covers and take a look.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
Has thanked: 1613 times
Been thanked: 4077 times
Electrical part of the ignition switch, about 50 USD to replace new.
atucker1
Year and Model: 1995 850 Turbo
Has thanked: 11 times
Been thanked: 15 times
Post by atucker1 »
Just FYI if you need instructions for ignition switch replacement Robert DIY (as usual) has an excellent video on youtube.
1995 850 Turbo, Sedan
1996 850 N/A, Sedan
Broken850
Post by Broken850 »
Update time! I jumped 12v to the green solenoid wire and the starter just barely moved. So I jumped 12v to the starter side of the solenoid with heavy gauge wire. The starter turned the engine very slow and just for a half second. The battery is showing a healthy 12v and maintains 12 while trying to start. Decided to change the starter, but still no good. Pulled open the steering column covers and found a charred black wire that looks like a ground for the switch. Any suggestions?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Post up a picture of the melted wire and we will do our best with suggestions.
..Lee
Broken850
Post by Broken850 »
I removed a good section of burned wires and repaired several that I couldn't replace. She fired right up, but is hesitating. I'm thinking I have more damage elsewhere. Tomorrow is another day....
Broken850
Post by Broken850 »
More info.... I removed the ignition switch and I have 10-12 volts on the switch housing. Doesn't seem normal, but I'm not really sure. Any thoughts?
Post by Ozark Lee »
Battery voltage on the housing is a bad thing, it means the switch is shorted internally. You will need to replace the switch before you go much further on the wiring repairs.
