1998 V70 Timing belt, cylinder head work 330k miles!
5rivers
- Year and Model: V70 1998 T5
- Been thanked: 15 times
Well, so far I have lapped all 20 valves! And installed them. Problem is there is some leakage - not major - but enough to see water around the valve seats. I have taken all the valves out and will lap them again. My question is should I be trying to achieve a sharp/noticeable edge on the underside of the valve seat to eliminate the seepage? Any links illustrating this would be greatly appreciated!
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
- Year and Model: Many Volvos
- Been thanked: 76 times
I use the dye and lap until it is gone on the valve and the seat. The valve and the seat should both have fairly sharp edges on the parts where the dye has ground off.My question is should I be trying to achieve a sharp/noticeable edge on the underside of the valve seat to eliminate the seepage?
5rivers
Ok, thanks Lee!!
5rivers
5rivers
Back again after a bit of a hiatus...and sanding the bottom of the cylinder head. I am about to begin re-assembling all the parts extracted from the motor area and have a question about the throttle body position sensor. The TBPS was attached to TB on the intake manifold when I removed it from the engine and accidentally left on the TBPS when I began to soak, wash, scrub the intake manifold! I figured it was toast and picked up another the salvage yard. The small bolts that attach the TBPS to the TB were pretty rusted and somehow were misplaced. Does anyone know what size and length these bolts should be?
I have also discovered that one of the 40 or so bolts that keep the camshaft cover in place and attached to the cylinder head has been stripped near the bottom of the bolt inside the cylinder head. Thanks in advance for any suggestions on what to do with this condition.
Appreciate any/all replies!
5rivers
- Has thanked: 312 times
- Been thanked: 818 times
The bolts for the TPS are M4 x 0.7, 1 cm long from tip to tip.
The cam cover fastener, is the bolt stripped or the head stripped? If it's the bolt just get another one. If it's the head, I would probably try a chaser tap or even to to get by with turning the bolt in gently and having the other 39 (and the top threads) do the job. But I am not a machinist, maybe someone with those skills will chime in.
Sanding the bottom of the head, yikes that makes me shudder to think about it! I always have the shop do that part and try to not touch it at all.
The cam cover bolts don't have much torque on them (12 ft lbs) so a Helicoil is more than good enough if the head is stripped and not the bolt.
5rivers
Hey, thanks for the replies!
I did find some small bolts to secure the TBPSensor to the throttle body. They were from inside an old non-useable 1996 honda accord distributor!
When I took off the vacuum tree, I noticed significant buildup of rust, etc underneath certain sections of it. I suspect the bolts which have various degrees of stripped threads may have loosened or hardened in place pushing up the vacuum tree and allowing moisture and other gunk to settle. I will see what using a flat file will do. May have to replace the intake manifold if I can't find my tap set.
On the cam cover, the last two or three threads on the bolt in question are stripped, not the head. I do have extra cam cover bolts that I can use.
What is a Helicoil? I have not heard of this, ever!
I sanded the bottom of the cylinder head down to .003" with a few sheets of 120 sandpaper; it took a while to reach that level of flatness (in between days of rain) with a few pieces of level/square wood, a large square, and a feeler gauge. I will attach pics. I experimented on the extra cylinder head I picked up from the salvage yard first before proceeding on to the head from my car.
Is it necessary to use sealant or anti-seize products on the camshaft cover bolts or on the bolts used to attach the manifolds? When I extracted the bolts some had white-colored product on the threads. I had to use a small brass brush to remove most of the material which was made easier after soaking the bolts with WD40. They now screw in with less resistance.
5rivers
No sealant or other product on the cam cover bolt threads.
Be sure to use the anaerobic gasket maker to seal the cam cover back down.
5rivers
Ok, thanks, erikv11
I picked up some red hi-temp RTV silicone instant gasket at harbor freight. Is this acceptable to seal down the cam cover?
5rivers
- 16 Replies
- 5310 Views
Last post by RickHaleParker
- 5470 Views
Last post by jimmy57
- 2337 Views
Last post by precopster
- 3162 Views
Last post by erikv11
- 5121 Views
Last post by kallekula
