2001 v70 t5 Abs pump will not turn off
kbaer28
Year and Model: 2001 V70 T5
Post by kbaer28 »
I was driving the v70 this morning and the abs and stc lights came on. As I slowed I could hear a pump running. I opened the hood and it is the abs pump. I shut the vehicle off and the pump does not turn off. In order to turn it off I have to pull the abs fuse.
Any ideas other than the module? Any way to confirm?
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
Only the module controls the pump. Did it trigger the abs light?
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
kbaer28
Post by kbaer28 »
Abs and stc lights came on. As well as service Abs soon. Someone had been inside the module before I bought the car. It was pretty hacked up and siliconed. I peeled the silicone away and took it apart. There was moisture inside of it. The board didn't look great. Lots of corrosion from the moisture.
I ordered a rebuilt unit from xemodex. I assume it will fix my problem but I will update this with my results.
kbaer28
Post by kbaer28 »
New abs module fixed the problem.
