1999 V70XC severe shaking on acceleration
Jack Rock
- Year and Model: 1998 V70R
As per the title, my car shakes or shimmies quite badly when accelerating 50km/h to 80. When cruising it is smooth. It comes and goes, sometimes mild, sometimes severe. It's more of a side to side shimmy rather than a hopping if that makes sense. I have checked all front end components, everything is tight, no rattles, no noises. Prop shaft was removed a year ago. Braking is smooth, steering wheel doesn't shake or wobble side to side. I put my snow tires and wheels back on to see if it's a tire issue - same thing. Recent changes are a new front wheel bearing, outer tie rod end and alignment. Any ideas are welcome, thanks.
1997 850 T5 (gave up at 324,000km)
1998 V70 R AWD (gave up at 296,000km)
1998 S70 T5 (total loss - in a parking lot!)
1999 V70XC
1975 VW beetle
1960 Empi Sportster Dune Buggy
1999 V70XC
1975 VW beetle
- Year and Model: Many Volvos
- Been thanked: 76 times
Your symptoms are typical for a bad inner CV joint on one of the axles. Many of the cheap aftermarket axles do the same thing right out of the box.
The inner joints are tough to diagnose since they don't have the "clacking" sound when you turn that a failed outer CV joint exhibits. Since you replaced a hub recently that is the side I would focus on. Sometimes the joint can get stressed or hyper-extended when the hub is removed.
When I did my front wheel bearing I broke the inner CV joint cage pushing the shaft out of the hub, just like Lee warned. I got a PnP from Erie VoVo for 100 USD next day and was back on the road, humble and better educated.
Jack Rock
Oh wow, I did not know that. I probably wasn't careful enough with the axle when I did the bearing. It started right after that. Don't you hate saving money only to have it cost you more
It sounds like a very probable cause, is there a way to be sure before I go buy one?
1999 V70XC
1975 VW beetle
1999 V70XC
1975 VW beetle
I tried to inspect mine but ended up popping it out to have a look. When the little metal pieces fell out and ran around the driveway laughing at me, I began to suspect the problem was found.
Thread here
https://www.matthewsvolvosite.com/forums ... ng#p340518
Thread here
greenman86
- Year and Model: 98 S70 T5-M
I have never personally dealt with the issue on my own cars but I have worked on newer Volvo's ( s60s) where this is more prevalent. There are no obvious signs that you will be able to physically see on the inner joint. If you are low on funds, a used parts supplier like Erie Volvo is your best bet. I am certain that you have to get a cv axle that is specific to your xc70.
Jack Rock
Ok, finally had time to change out the right front axle on the weekend. Although the inner boot didn't look ripped there was grease all around it. I thought this was it but on road test there was no change. Still the same terrible shaking. Next steps?
I'm about to give up on this car actually, too many little things wrong which I could live with (cat, non functioning fuel gauge, huge cloud of blue smoke on cold startup). I was hoping to drive it to death as I'm not willing to fix these things but the shaking is so bad it's barely driveable. The car only has 210,000km on it.
1999 V70XC
1975 VW beetle
1999 V70XC
1975 VW beetle
Engine mounts possible. Especially the lower right main mount
Jack Rock
I will check them out. It is definitely a side to side shake, although the steering wheel stays stable. It's hard to explain, as if the road is moving side to side and the car stays with it, therefore it drives straight and steering wheel is still but your coffee still spills. The frequency of the shake is a similar rate to when you have out of balance tires.
1999 V70XC
1975 VW beetle
1999 V70XC
1975 VW beetle
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
Weird - have you checked the other side driveshaft? You can feel the inner cv joint by grabbing the axle there and trying to move it up and down (radial play), no need to remove anything but the wheel. That bad a shake you should be able to feel that way. Aince the wheel swap didn't resolve it I can't imagine it's related to the wheels, balancing etc. Are all the suspension components really tight?
