2003XC70 Steering rack = mush
carboncow
Year and Model: 2003 XC70 2018 S60
Post by carboncow »
Our third car in the family...it's seeing much love these days. I bought new loaded struts, sway bar links and what I thought was a need for inner and outer tie rods. My tech buddy was going todo it today and said the steering rack is mush inside...which explains why it doesn't return to center very well either!
What is the PIA factor for swapping the rack on an XC70?
This car was a salvage I bought back for $600 as it's got a bump in the rear end. Looks fine but they totaled it. I'm sure I don't want to be $1500 into it but I see used racks on ebay for $200-300. What should I expect for time/labor/hassle?
Thanks!
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
rack... how rusted? does it leak fluid already? if not, then give it a good cleaning, and make sure to put oetiker clamps (no tieraps here).
If the steering doesn't have that balanced light-heavy volvo feeling, I would suspect mostly a tired p/s pump
carboncow
Post by carboncow »
No fluid leak. He explained that the worm gears are worn inside...thus sloppy. I may have not been clear but the symptoms are like bad tie rod ends...but it's internal issues.
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
oragex
Post by oragex »
It is rare for a rack to have worn gears. But maybe it can happen.
I thought by mush you meant there was rust inside the dust boots, on the rack rod (caused by improper boot clamps)
I remember I had a bent ball joint and the steering felt very 'disconnected'. Had three garages in a row trying to convince me I need a new steering rack. Good part of the story is that's when I started to do my own repairs :)
