i've got about 152k. the drive shaft is clicking when i put it into gear, park to reverse, neutral to drive, etc. i don't always get a click, but most times. it's a single click when going into gear. no vibration, no constant clicking while rotating.
had to replace the entire shaft assembly in my 2000 years ago. does the '05 require the entire replacement or are their components that can be replaced?
2005 xc70 drive shaft replacement?
mrscullini
- Year and Model: 05 XC70, 08 XC70
Reason: Clarified title - please, no triple question marks in titles
If it is in a CV joint very likely can save replacement cost my removing it and re packing it with grease. A single click is probably one worn ball/race and lots of grease will quiet it if you have led a good life.
I don't know the XC shaft system well but can you isolate exactly what component makes the click?
mrscullini
i think i've led a good life.abscate wrote:If it is in a CV joint very likely can save replacement cost my removing it and re packing it with grease. A single click is probably one worn ball/race and lots of grease will quiet it if you have led a good life.
i can't seem to isolate it. i'll have to crawl under again and take a closer look. are there cv joints at both ends of the shafts?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
One rather common issue is the shaft bolt getting loose - the bolt that shows up in the center of the wheel. This is a stretch bolt and needs replaced with a new part if it has loosened up.
The upper rear and the lower front engine mounts are also known to weaken over time
mrscullini
thanks. the shaft bolt, i can't get a mental picture. can you please explain further.oragex wrote:One rather common issue is the shaft bolt getting loose - the bolt that shows up in the center of the wheel. This is a stretch bolt and needs replaced with a new part if it has loosened up.
i'll check the motor mounts. this was something i had to replace on my 2000.
- oragex
mrscullini
a little more info, the sound seems to be coming from the front half of the shaft at the angle gear. the sound is a metallic pinging, tinging when you drop it into gear. brake applied, not rolling, shifting from park to reverse or drive.
there is a u-joint of sorts at the shaft interface with the angle gear, correct? i would imagine this joint is likely the issue. can this joint be serviced without replacing the entire shaft?
there are no other noises present.
mrscullini
so the noise seems to be coming from the front of the shaft at the bevel gear. is there any maintenance that can be performed on this joint.
JRL
- Year and Model: Several
- Been thanked: 16 times
First tighten and glue (using red locktite) the axle bolts and or buy and use a pair of XC90 axle bolts
Trust me on this, try it first.
You glue and let it sit without moving it an inch for at least 12 hours or overnight
Cured mine and the clanking in and out of gear was pretty bad, now 99% quiet.
This is almost always the issue and the cure
mrscullini
thanks JRL. you are talking about the center bolt that holds the hub for the front wheels, correct?JRL wrote:First tighten and glue (using red locktite) the axle bolts and or buy and use a pair of XC90 axle bolts
- 5198 Views
Last post by SuperHerman
- 681 Views
- 3238 Views
Last post by 850 LPT
- 607 Views
Last post by chrism
- 884 Views
Last post by ddavis6900
