The I Worked on My Car Today Thread
2000 V70 Tailgate Trim Rattle Fix
whoa
- Year and Model: 850 Turbo Wagon 1996
Redid my ABS module repair, which had failed on me after not many miles. The ABS light would usually be on after a little driving, and when not on, sometimes the ABS would kick in during non-skidding braking. So I re-did the soldering and did a more thorough job on the two wires from the module to the pump---the insulation had rotted away. This time I cut off the plastic cap on the pump so that I could get to those wires where they enter the pump; I wrapped them with electrical tape. An initial test drive was promising; the light stayed off and the ABS kicked in appropriately when braking hard with a tire over a manhole cover.
1996 850 Turbo Wagon
- osman
- Year and Model: 2002 c70 hardtop
Today I met a forum member in my area with a 99 T5 S70 255K and helped him replace/repair his dash mounts, installed new front seats, and replaced recirc motor. Started at 11 AM finished at 7.
Did I win? I hate doing dash mounts.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
taffbouncer
- Year and Model: V70 2055
thanks Mike - hadn't considered the tailgate
By the way - I have ditched the crappy amber bulbs and fitted silvered indicator (turn) bulbs - still glow amber. Get a better look on the front and rear clusters. £8 a pair in Halfords. Be sure to get the off centre pins on the bulbs - there are two types
PDLarson
- Year and Model: V70XC, 1999
- Been thanked: 2 times
Replaced the fuel filter. I had a heck of a time with removing the fuel lines. I finally got some better light in there and saw there are some plastic rings below the metal parts of the connectors, those are what need to be moved up into the connector to remove the fuel lines. I hated hacking up my car but it runs now
Winter in Montana, AKA: XCs are great!
1999 V70XC / Mostly stock under the hood / Several cosmetic mods inside and outerikv11 wrote:PDLarson has been spot on.
2008 XC90 V8
Not so much today but the last two weekends. Transferred the front suspension, control arms and flex brake line from the 98 S 70 to 94 T 5, Last weekend transferred E brake cable and installed new pads. Also had to manufacture and install passenger side rocker panel.
93 850 GLT
96 850 GLT
98 S 70 GLT
88 Bertone
94 850 Turbo
96 850 GLT
98 S 70 GLT
88 Bertone
94 850 Turbo
- Has thanked: 1613 times
- Been thanked: 4075 times
Dived into my P80 today for a long week of work in the cool mornings
PCV overhaul...never done on this car, 170k miles
Oil change
Coolant change
ETM cleaning
IPD turbo boost spring
New vacuum hoses.
New clamps on induction system
Oil change
Coolant change
ETM cleaning
New vacuum hoses.
Ben850
- Been thanked: 7 times
I detailed my wagon at my friends airport hangar. I worked on his 1963 Lincoln Continental.
I installed a Holly 750 in place of the original Carter. It is the manufacturers alternate recommendation.
It worked and he was very happy to have it running again.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
That's a gorgeous car. I think you could fit an 850 in the trunk.Ben850 wrote:I detailed my wagon at my friends airport hangar. I worked on his 1963 Lincoln Continental.
Still nibbling at my PCV and hose replacements. 30-60 minutes at a time since I have ip overseas company for three weeks.
I'm convinced the easiest way to remove OETTINGER clamps is with my favorite tool, Dr Dremel.
Trying to pick open the clamps on the small turbo hoses is absolutely nasty, with limited access for hands, tools, and back breaking to reach in the engine bay.
My OEM heater hoses are still in great shape so I will keep/ offer to someone restoring/ maintaining on a budget.
- 21 Replies
- 6808 Views
- 966 Views
Last post by Craigd2599
- 1969 Views
Last post by rspi
- 835 Views
Last post by Clemens
- 26 Replies
- 6778 Views
Last post by ChadLee
