Hi everyone.
I write to you from the cold Russia))
On my machine with the engine Volvo s70 V5234T3 error occurred P0172.
Scanner shows the MassAirFlow at idle 2.5 g/s -this is normal for a turbo?
please help: where to start to solve ?
1997 S70 Error P0172
- Year and Model: Many Volvos
- Been thanked: 76 times
Welcome to MVS,
The P0172 code is almost always due to a vacuum leak. On the end of the intake manifold, #1 cylinder end, there is a rubber elbow that has a bad habit of either rotting or falling off and most of the time the leak can be traced to that point. If that elbow looks OK then check the rest of the vacuum lines.
The elbow is well hidden and it is in a very tight spot behind the power steering pump and the alternator.
There are some good pictures of the "usual culprit" elbow in this thread.
https://www.matthewsvolvosite.com/forums ... hp?t=49113
As far as the idle speed MAF reading goes, I don't know. I don't have a scanner that has a real time data function other than VIDA/DICE and I can only use that on my '99. All my scanner does is read and clear the P codes.
- Been thanked: 4068 times
Here is some data from my T5 2.3 liter turbo engine. I think 2 g per sec is low... I recorded 4-4.25 g per sec
- 5790 Views
Last post by matthew1
- 538 Views
Last post by flat_tomato
- 23 Replies
- 4330 Views
Last post by precopster
- 2180 Views
Last post by McKennaR
- 960 Views
