1995 850GLT Battery Use/Charging
viper69
Year and Model: 850GLT 1995
Has thanked: 77 times
Post by viper69 »
Quick question, I don't always have the time to use my car due to traveling. I have a Battery Tender that works quite well.
However, someone also mentioned to me some "gadget" that you put on the car's battery terminal (unsure which one) that in essence turns off the connection from your battery to car.
I thought this may be a better alternative than using my Battery Tender when I'm gone for a week or 2.
Any idea what this gadget is and where to buy one?
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
Been thanked: 4065 times
2 weeks is fine to leave a Volvo. If your battery discharges during that time you have an electrical problem to fix.
The gadget is a terminal knife switch or terminal switch. They are commonly used in marine applications.
Each time you disconnect the battery the ECU has to relearn the fuel mapping and all the OBD monitor circuits go not ready, too.
viper69
Post by viper69 »
abscate wrote:2 weeks is fine to leave a Volvo. If your battery discharges during that time you have an electrical problem to fix.
So the OBD computer forgets what's going on? That would suck.
Volvo 850 GLT 1995
It will clear the codes but also reset the monitors until you perform about 100 miles of driving. The car will test as " not ready for inspection" at most emission tests until this is completed.
viper69
Post by viper69 »
abscate wrote:It will clear the codes but also reset the monitors until you perform about 100 miles of driving. The car will test as " not ready for inspection" at most emission tests until this is completed.
Thanks, I will stick to my Battery Tender then.
The service light just popped on, so I need to check the little light box up front, and see what the code is when I press the button.
Volvo 850 GLT 1995
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
It can be...in the summer...if battery is fully charged before you park it for two weeks.In the winter....it will be dead after a week.
If the car have aftermarket alarm system installed.....battery will be almost dead after just a week of not starting it.
@viper69....service light is just an oil change reminder,not check engine light. :!:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
viper69
Post by viper69 »
I can never remember what the Amber Service light is for. So I always end up checking the computer under the hood looking at the flashing lights when you push the buttons.
SO, the amber light is only for oil changes?? Either way, I have to turn it off, because I doubt Jiffy Lube etc, will know how to turn it off.
Volvo 850 GLT 1995
misha
Post by misha »
You can turn it off yourself under the hood via built in obdI system.
ObdII system requires specific Volvo scan tool to reset it and to access the codes.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
viper69
Post by viper69 »
misha wrote:You can turn it off yourself under the hood via built in obdI system.
Hmm.. I know I have turned off a light in the dash from under the hood, w/out special tech. Just using my fingers. Perhaps it was a light that was not the Amber service light. Does a 95 Volvo have Obd 1 and Obd 2? I thought it only had OBD1 system.
Volvo 850 GLT 1995
misha
Post by misha »
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
