i am listening. i have new bolts being delivered tomorrow. i'll report back.JRL wrote:You just don't want to listen to me, do you?
GLUE THE FRIGGEN BOLTS
They all start to do this over time. The splines become worn and the play becomes bigger, hence the louder noises
2005 xc70 drive shaft replacement?
mrscullini
- Year and Model: 05 XC70, 08 XC70
- Year and Model: Lots
- Been thanked: 128 times
Visual image of steam being vented all of a sudden by a pressure cooker.
JRL
- Year and Model: Several
- Been thanked: 16 times
Seriously, I just went through this on mine and have done several others. If it doesn't get rid of the clicks completely, the noises should be seriously reduced and be liveable.
mrscullini
thanks jrl. i don't doubt your knowledge. hopefully i will be replacing on friday.JRL wrote:Seriously, I just went through this on mine and have done several others. If it doesn't get rid of the clicks completely, the noises should be seriously reduced and be liveable.
battling a new issue, please see my latest post and weigh in.
mrscullini
axle bolts arrived today. can i replace with the car on the ground, wheels loaded? just simply take out the old and install the new?
JRL
Do not overtighten.
I just heard of a couple of guys snapping these bolts.
Use the correct torque spec
mrscullini
thanks. i read of a couple guys doing the same. i have a torque wrench and angle gauge.JRL wrote:Do not overtighten.
is it ok to replace with the car on the ground?
mrscullini
new axle bolts in. i used loctite and the correct torque spec. i also let them sit over night. the clicking is the same. where else should i look? can i rule out the drive shaft and assume it is related to the axles? is it ok to leave it as is for now or is it the precursor for a major failure?
- 5308 Views
Last post by SuperHerman
- 698 Views
- 3271 Views
Last post by 850 LPT
- 613 Views
Last post by chrism
- 887 Views
Last post by ddavis6900
