Hi all,
I'm in the midst of a Head Gasket job and I broke one of the exhaust manifold studs. The writeup on tracytruesoaps (Volvo 5-cylinder: How to Replace the Head Gasket) which is for NA engines, says to remove the exhaust manifold. Mine is tubo and after a little research here I found another great writeup that doesn't require removing exhaust manifold. (http://www.atthetipwebs.com/technologyi ... gasket.htm)
You just take off the bolts attaching to the head and leave the manifold attached to turbo.
Now what's my concern. If I leave the broken stud like that, how likely you think it be a problem?
What do you think?
Broken Exhaust Manifold Stud
- Year and Model: Many Volvos
- Been thanked: 76 times
It is a pain but if you remove the turbo you can double nut what is left of the stud and remove it. I had several bad studs and I bought replacements at the auto parts store. There is nothing special about them.
You can try it but pay attention. Exhaust leaks tend to actually eat away at the manifold and the flange on the turbo. A relatively small problem can turn into a much bigger problem after the leak develops.
Volvich
- Year and Model: 1998 Volvo C70 Coupe
In case anyone is interested the car is now for sale in Los Angeles.
See the ad here: https://www.matthewsvolvosite.com/forums ... =6&t=70959
- 1868 Views
Last post by RyanJohnRyan
- 1425 Views
Last post by projectsmorol
- 489 Views
Last post by Pretribrapper
- 2676 Views
Last post by jefe
- 9 Replies
- 3569 Views
Last post by vtl
