2008 XC90
Forum rules
warcraftjunkie
- Year and Model: 2008 XC90 3.2
10/31/2013 - Oil changed at dealer with 70,500 miles. They recommended new front brake pads and rotors, which I declined.
If you can't laugh at yourself, someday you will be the only one not laughing.
08 S80 V8 - My daily driver
08 XC90 3.2 - Wife's people hauler
87 245 DL - Son's car
warcraftjunkie
11/23 - Changed front Disc pads at 71,000 miles. Rotors definitely have a lip on the outer edge but fall well within the specs for safety. Will change the Rotors next go. Also rotated the tires.
warcraftjunkie
5/5/2014 - 78,000 miles
Changed oil with Mobile One 0-30w synthetic as well as filter. Noticed some type of oil underneath the transmission case.
warcraftjunkie
12/21/2014
87,327 miles. Changed oil with Mobile One 0-30w synthetic as well as filter. No issues found under the hood.
warcraftjunkie
7/12/2015 - 96,000 miles. Changed oil and filter with Mobile One 0w30 full synthetic. Also replaced the interior cabin filter, as well as the engine air filter.
Having some transmission shifting issues. Transmission has excess vibration around 2800RPM to 3200RPM. Seems to be a shift flare between 2nd and 3rd gear. The car is currently at the dealer where I'm certain they will recommend changing the fluid. Will do so and if the problem doesn't go away I still have some mileage left before warranty falls off.
warcraftjunkie
2/7/2016 - 105,200 miles. Changed fuel filter as well as rear brake pads. Rear rotors still seem to be in good shape. Will replace them next time I touch the rear brakes.
warcraftjunkie
2/13/2016 -105,300 miles. Changed oil with 0-30w full synthetic Mobile1. Had a nail removed from rear right wheel.
