1998 V70-XC Engine dies after 2 seconds
doehan
Year and Model: v70 xc awd 1998
Post by doehan »
Yesterday I changed my timing belt and also the serpentine belt on my 98 XC AWD (155,000 mi, clogged pcv)
After that the car starts fine like as always, but stops with jerking (sudden decrease of rpm) after just one or two seconds.
(with stuttering + wobbling noise)
When I tried to push gas pedal, the rpm goes up but anyways it stops within two or three seconds.
I did so much things at once, PCV replacement, PTC cleaning, distributor, and spark plugs + wires.
Thus, I can't figure out what is the problem...
The only thing suspicious is: when I was changing the timing belt, I couldn't see the little notch on the crankshaft. So I just aligned the indicator at the valley of the shaft between two 'V' signs on the tooth of the crankshaft, but camshafts are aligned properly as indicated.
Does it cause the engine stop? or maybe it would be the fuel line (injectors) or vacuum line but I don't think that is the problem because the car starts good anyway..
Need your help urgently.. Please
Thanks.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The way you describe the crankshaft marks you did it exactly right. There are two versions of the mark(s) on the harmonic balancer. The older version has a single V shaped notch in the valley of the sprocket and the later version has two V shaped notches on the peaks of the sprocket and the mark centers between them.
The timing being a tooth off won't cause the car to not run. I suspect that about 10% of them on the road have the belt off a tooth and people don't even know. They run better when the timing is correct but they don't run awful when they are a tooth off.
I suspect you have a fuel pressure problem. There is a Schrader valve on the end of the fuel rail and you need to check the fuel pressure at that valve. Ideally you would use a fuel pressure gauge but you can use a tire gauge. The tire gauge won't be terribly accurate and it generally destroys the gauge in the process but it is a quick and dirty check. Protect your eyes to avoid getting gasoline sprayed into them - I can tell you from experience that gasoline in he eyes is painful.
What you are looking for is about 43 PSI with the key in position II but a tire gauge likely won't read that high. What you do want to do is verify that there is pressure.
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
maybe something is off in the plug wires, distributor or coil area? left unplugged? You did do a lot on maintenance, just work backwards and re check everything a few times. solution is starting right at you probably. sounds like you did timing right
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
superfeed
Year and Model: 1998 V70 XC
Post by superfeed »
Jumper out the fuel pump relay and see what happens.
doehan
Post by doehan »
Thanks all, I'll work backward and try to re-check all of them. I checked the MAF sensor and I've found when I pulled out the connector of the MAF, the car runs continuous (more than just two seconds) with huge backfires and misfires. Is it possible to have intake manifold leakage? Thanks again.
Been thanked: 504 times
Post by cn90 »
Check for any pending codes. Maybe the MAF is on the way out. If so, Bosch only, no other brand.
Scholz
Year and Model: 1998 S70T-5
Post by Scholz »
I feel as if the ECU should be robust enough to prevent a massive amount of backfiring. Are we sure we didn't muck up the firing order on the cap and wires? Other than that in my own experience the ECU retards the timing a large amount when it loses input voltage from the MAF which in a few hondas i've owned would do the same thing with the MAF disconnected and the timing off.
My money is still on timing whether its the distributor or something more nefarious.
