Something Is Going on with the O2, but the read out in saying.
1. Check circuit fuse. Checked OK
2. Relay defective. Where is this and how to check?
3. Check circuit wiring. Where to start on this?
Any help would be great. Didn't see much in the forum.
2006 V70 2.5T pulled code P0036
DGM
- Year and Model: V70 2.4i 2005
- Been thanked: 3 times
I found the following wiring diagram for you. Basically if you read battery voltage on fuse 11B/14, the relay FMA3 (unit 2/32) isn't a concern. The unit 7/15 is the front oxygen sensor, the unit 7/82 is the rear. As per obd code P0036, you experience a problem with the heating element circuit on the rear sensor.
You can verify that you have battery voltage at pin #1 when rear sensor connector is open (green/brown wire). If present, most likely the heating element of the sensor is defective/open. If not trace accordingly.
Have fun...
Have fun...
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
As wife was driving to store yesterday, noticed something hanging down from car. Forgot about it till this morning. It's wires. So I assume something has come loose and causing the problem, or my local groundhog mechanic has been working on the wrong car. Will check it out after work today.
Thanks for the diagram. It will come in handy.
Shane
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
obayha
Here's what I found tonight. The Walmart bag was melted to the cat and you can see what a mess the wires are.
Are there any major problems driving the car about 70 miles tomorrow. Misses has appointment and wants an answer from someone other than me.
Will it shut off or just run a little different?
Shane
Shane
1998 V70 T5 331,000
obayha
Would it be a good idea to rewire?
And are the white wires the same?
1998 V70 T5 331,000
DGM
Yes depending of your skill to solder new wires with heat shrinks. Most will simply replace the sensor at this point.
They are the heating element. No particular polarity on them.
However with the other two wires you must respect polarity.
I suggest not to run for long without the sensor connected. At least not with the hole unplugged (exhaust leak). The rear sensor is there to monitor CC efficiency.
Hopes this help,
Hopes this help,
obayha
Thanks for the reply. Working on the rewire today. Hope it warms up a little. Not quite 100 yet.
Anyone know the nut size, before I crawl under there?
Shane
Shane
1998 V70 T5 331,000
obayha
One more question. Will the CEL reset it's self or do I need to do the battery removal?
Could not budge the O2 sensor, so I work with everything under the car. Not my best work, but we will see what happens.
1998 V70 T5 331,000
- Been thanked: 4068 times
Removing the battery negative terminal for 10 minutes (have your radio code handy) will reset the CEL.
How old is your O2 Sensor? It might be time to replace it anyhow.
