99 S70 Lost a pin from shifter button
v-45magna
Year and Model: 99 S70 GLT
Has thanked: 2 times
Post by v-45magna »
My auto shifter button pin is lost. It is the pin most visible at the top in this screen grab from a DIYrobert video. It is the also only pin installed in the button part itself. I am looking, but if I don't find it, does anyone have one out to measure the length on? Diameter would be good info too, but I think it is the same diameter as the other pins. I figure a trip to the hardware store (an actual, good hardware store) and I should have my replacement without resorting to a trip to a pick and pull.
I pulled mine apart a while back to see if it was repairable. I then decided to order a repair kit and they were always out of stock. I had the dash out and under repair so it sat around and eventually got up and walked away on its own apparently. Now I have the dash back in, going back together with everything. My new shift button arrived and no pin.
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
find one at the junkyard/salvage yard? or just buy a second hand shifter knob on ebay?
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
dosbricks
Been thanked: 4 times
Post by dosbricks »
I saved the good button out of my cracked up 850 shift knob.
The top pin is 3mm x 25mm long.
v-45magna
Post by v-45magna »
Thanks dosbricks!
Just now, I found an almost perfect specimen to replace it in my junk parts and fasteners. It came out of a bag of scrounged bits from a long defunct Daisy powerline 92 co2 pistol. But frankly, I wouldn't care if it came out of a coffeemaker as long as it worked. This one was actually better than the original as it has a knurled section on one end that keeps it from backing out from one side. Came in handy during reassembly.
And so, it is fixed.
dosbricks
Post by dosbricks »
Cool
v-45magna
Post by v-45magna »
Is it weird that I get a little kick out of fixing stuff for $0 with my saved junk bits? Ha ha! I don't care. :D
mika
Post by mika »
this fix is the definition of "getting a kick out of saved junk bits." Funny how the springs loops under the pin, but only after everything is installed. Its frustrating to get it right
'97 855 N/A
