Hi all,
I'm not familiar with P2 cars, but I want to check out a 2003 V70 this afternoon that looks nice, has a 5-speed and only 64k on it.
I did a quick search but did not see anything specific on common problems. Is there anything other than what I know from my P80's that I should watch out for?
Thanks, Dirk
2003 V70 looking to buy
- 850 LPT
- Year and Model: 96' 850
- Has thanked: 331 times
- Been thanked: 242 times
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The manual transmissions were flawed by a slave clutch cylinder failing
http://www.volvoforums.org.uk/showthread.php?t=131170
The instrument panel also fails in the 2003 but 64k is still early. Test the PCV as shown on Youtube.
- Has thanked: 1502 times
- Been thanked: 3817 times
MTTF from the UK data seems to be about 130k
My guess is UK drivers shift a lot more than US driver. My 1999 stick has had 6 teens learn to drive, tows boats, and is still on the original clutch components.
- 850 LPT
130k is not so bad. Does this model have the internal slave cylinder?
13' Honda Odyssey
13' Honda Odyssey
I think they do Dirk. Referred to as the Concentric Slave Cylinder or CSC on other Fora.
The P2s are awful nice cars - close the deal on that manual quick.
No ETB worries on a 2003 - they were either DENSO or Bosch, not MM though!
The PCV uses the late P80 thermostatted one so it doesn't clog like the P80 cars.
- 850 LPT
Ends up being too expensive for me. $5200 plus $595 dealer fee
, plus they won't budge. Then add tax and registration. It also needs a timing belt right away and has some cosmetic issues. That's what I know without seeing the car.
Thanks for the info, Steve. If you want to check it out, the car is at Paul Miller Value Center. It's in my favorite color: nautic blue
13' Honda Odyssey
13' Honda Odyssey
- 850 LPT
Well, the one in question here did not work out but I'm going to look at an 05 tomorrow that looks really clean.
I have a quick question, do these cars have the notorious evaporator fail problem like the P80 cars or did Volvo improve on that on the P2's?
Thanks, Dirk
Thanks, Dirk
13' Honda Odyssey
13' Honda Odyssey
- oragex
No issues with the evaporator. Possible issues with the A/C compressor loosing gap but it's a 10 minutes fix. The points to look at are the control arm bushings, transmission shifting butter smooth when warmed up, perhaps a PCV check. Shock absorbers get stiff after 100k miles.
- 850 LPT
So I bought the 05 V70, my very first P2 car. I'm now waiting to go pick it up, probably in the middle of next week.
It has only one owner, 109k, it's super clean and well maintained. I couldn't believe the records this car came with. The PO had all the scheduled maintenance done at 15k intervals and he even brought the car to the dealer for oil changes.
Needless to say the PCV system is in good shape. It is in need of some suspension work, but that's ok because I can do it all myself. Timing belt is due soon as well, again not a problem, I might have my indie do that.
This car is somewhat of an oddball. It's a base model (non turbo, 5-speed manual), but loaded up with all kinds of options: leather, sunroof, rear parking assist, alloys etc. The dealer suggested it was a special order car, could that be true?
Photos to follow soon...
13' Honda Odyssey
13' Honda Odyssey
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
My wife drives one of these, a very nice car. No park assist though, not sure Volvo had it for 2002 model year.850 LPT wrote:This car is somewhat of an oddball. It's a base model (non turbo, 5-speed manual), but loaded up with all kinds of options: leather, sunroof, rear parking assist, alloys etc. The dealer suggested it was a special order car, could that be true?
