Running NGK Cu plugs with 27000 miles on them. Car was running well, but gap had grown to over 0.040 inches. Spec in manual is 0.030 inches and many here recommend 0.028.
I regapped to a tight 0.030" fit.
Thinking back I'm not sure I checked gap on plugs out of box, but that was in a long since overwritten piece of RAM.
1999 V70 T5 measured spark plug gap wear
- Been thanked: 4064 times
- Year and Model: Many Volvos
- Been thanked: 76 times
My Bosch coppers tend to grow the gap to the 0.040 to 0.045 range after about 30,000 miles. They may do it quicker than that but I try to remember to check and re-gap them at that interval.
I have a theory about it. I think it may be a "memory" problem with the steel since the gap seems to grow back to the same point where it came out of the box, before I tightened it up when they were installed.
- Been thanked: 504 times
Or switch to NGK BKR6EIX (Iridium) and forget about it for the next 80K-100K.
I use a bit of antiseize to prevent galling at the next change.
I installed the NGK BKR6EIX (Iridium), about $7/each at local parts store, and the car loves it.
I pull mine every 2 years or so for compression tests so gapping the cheap ones works out better on my pocketbook. At my run rate 100000 miles would be 2025
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
I regapped my NGKs from around .038 to .028. Made no noticeable difference to performance or fuel consumption.
Noooo idea how many miles were on them. Probably a billion.
- Has thanked: 311 times
- Been thanked: 817 times
I have over two billion on a set of OEM plugs right now. So far.
No doubt zip tied in....
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
I just changed my plugs and put in a set of Volvo OEMs. Had a quick chat with the guy at the stealership, to confirm a gap of 0.03"-ish (0.75 mm). He looked bewildered and said he thought the gap was supposed to be 0.4 mm (0.015").
So I just chucked them in straight out of the box, since the dude assured me they were pre gapped.
F it. Car runs great.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
The North American user manual says 0.030 inches (0.75mm)
Its not confidence building when the dealer people don't know their stuff, is it? I could see a cold weather adjustment of a small amount, but not 1/2 the gap for you guys in Scandinavia
- 3878 Views
- 11 Replies
- 1559 Views
Last post by volvolugnut
- 2388 Views
- 6002 Views
Last post by pgill
- 4807 Views
Last post by Azik09
