Cannot put New timing belt on!
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Re: Cannot put New timing belt on!
Post by RussB »
cn90 wrote:It is round knob on the oil pump that usually prevents the TB from sliding in properly.
Yes indeed. The 850's (not sure about a '98 V70) have that "bung" with a rubber ring on it. If the rubber ring slides back towards the engine block, it effectively stops you from being able to get the belt seated on the crank pulley.
Before trying to install a new belt, feel up in there with your fingers, and you'll find what I'm talking about
Been thanked: 466 times
Post by cn90 »
I have done a few TBs job now, my little trick is to wet the TB with some soapy water, it makes it much easier to slide it in.
RussB
Post by RussB »
cn90 wrote:I have done a few TBs job now, my little trick is to wet the TB with some soapy water, it makes it much easier to slide it in.
That's kinky! :lol:
