If you want to look at what your system looks like, look at my old post here, where you can see how the top of the tank is laid out, and there are 2 fuel regulation devices. A fuel pressure valve and regulator.
https://www.matthewsvolvosite.com/forums ... =1&t=69887
fuel pump access hole cut. Pump issues
- Has thanked: 2203 times
Acjlarsen
- Year and Model: 2000 volvo v70xc awd
I've rectified my mistake. I got the lift in the left side tank back in and wired. I then bought an air nibbler and cut the hole in the correct side, put the new pump in plus new seals on both sides. No leaks. Now to patch the holes. The car starts right for the first time in a year. Heres a pic of the hole i should have cut the first time
- Been thanked: 4068 times
Are you going to weld that or Seal with JB or similar product?
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
scot850 wrote:If you want to look at what your system looks like, look at my old post here, where you can see how the top of the tank is laid out, and there are 2 fuel regulation devices. A fuel pressure valve and regulator.
Great thread! What a pain that set up is. wow!
- 2289 Views
Last post by rspi
- 1617 Views
Last post by Doc67
- 758 Views
Last post by AustinAbney
- 28 Replies
- 11955 Views
- 3919 Views
Last post by precisionguesswork
