99 S70 Base. Bad decision with aftermarket Radiator
ashlee2319
Year and Model: 2000 V70 NA
Has thanked: 3 times
Post by ashlee2319 »
A few months back, I accidentally broke the nipple off the top of my radiator. Bought a new aftermarket one, but my trans cooler lines didn't fit. Stupidly, I cut my lines and clamped hoses to them connecting to the radiator.
Looking something like this:
Today, I found a cut in one of the lines. Living in the middle of an Arizona summer, I know something needs to be done right away.
My question is---
Do I buy new trans cooler lines for my aftermarket radiator? (where can i find?)
Replace my hose with a hole in it? - Is this fitting bad for long term?
I like to think Im a mechanic and try to do as much as my own work as possible.
Any insight would be great.
2000 V70 N/A
1999 V70 GLT - Current project car
Has thanked: 1609 times
Been thanked: 4065 times
Perfectly good double clamped fitting. Replace it as before. I don't think there is a ton of pressure on these lines
ashlee2319
I found this pic on the internet. I only have single clamps on them but I guess I should do 2 because I always see/feel oil leakage. But regarding the life of my transmission, should I eventually replace it with new cooler lines? Everyday is 105 F+...
2000 V70 N/A
ashlee2319
***EDIT : I should probably mention my Heater Core went out today. Coolant everywhere on the floor.
2000 V70 N/A
double clamping will help that seepage. Keep an eye on your ATF level, do drain and fills regularly, and drive like a normal person and enjoy your car.
You can get a cheap heater core on eBay but it must be cleaned or they stink up your car, check threads.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Transmission fluid leaks are causes of major auto fires. I would spring for a proper rad for under $200. Not worth the risk.
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
If there is enough hose, cut the bad section out and re-clamp it, if not, replace. Get only TRANSMISSION HOSE to replace.
I have no problem with mine.
85 GLH, 367 whp
00 Insight, 72 mpg
ashlee2319
Alright, so I need one of those barbed couplers too. I have been using heater hoses from autozone, but I will buy trans hoses. Is it okay to clamp the trans hose onto the lower metal hose (original trans cooler hose)? I found another site of leakage.
2000 V70 N/A
Get at least an inch of hose onto the metal tube, fitting snugly, then double hose clamp that inch, and you won't have seepage nor leakage.
ashlee2319
Ok , thanks. Does the hose I need have the mesh looking insulation in it?
2000 V70 N/A
