98 V70 Tail light lens removal
98v70dad
- Year and Model: 98 V70
Do you have to remove the upper tail light lens to remove the lower lens? By just looking at bottom lens it looks like it wont come off without also removing the upper one. I'm replacing the left and right outboard tailgate bump stops and it looks like the only way to access the attach bolts is to remove the bottom lens.
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
Yes.
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
stephansvolvo
YouTube this Volvo v70 tail light removal and you will see a few videos done by RSPI.98v70dad wrote:Do you have to remove the upper tail light lens to remove the lower lens? By just looking at bottom lens it looks like it wont come off without also removing the upper one. I'm replacing the left and right outboard tailgate bump stops and it looks like the only way to access the attach bolts is to remove the bottom lens.
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
98v70dad
I did that yesterday and only found one for the upper tail lights. I didn't watch it because my wife was watching TV. I'll probably look at it tonight since I would guess that removing the lower ones involves the same steps.stephansvolvo wrote:YouTube this Volvo v70 tail light removal and you will see a few videos done by RSPI.98v70dad wrote:Do you have to remove the upper tail light lens to remove the lower lens? By just looking at bottom lens it looks like it wont come off without also removing the upper one. I'm replacing the left and right outboard tailgate bump stops and it looks like the only way to access the attach bolts is to remove the bottom lens.
