I found out once the plug popped out on its own after siren repair on wife's V70. Anyway, at this age the siren might have a bad battery. You can run the car with the siren unplugged, if you don't mind "Alarm service" messages. It does not affect immobilizer.
You have to read the codes, really.
RESOLVED 2001 XC70 Replaced Starter and Now Immobilized
deepsouth
- Year and Model: 2001 Volvo XC70
- Been thanked: 11 times
Cracked open the immobilizer and full of brownish fluid--batteries are shot and circuit board is totally destroyed. Going to leave it unplugged.
The starter is getting power to it so I'm taking off the new starter and going to take it back to AZ to get tested. Long shot but I guess it happens. I suppose next I should try the immobilizer antenna?
2000 S70 GLT SE, 175,000
2001 XC70, 129,000
2001 XC70, 129,000
deepsouth
RESOLVED!!! Turns out the AZ starter was bad out of the box. I suppose this is an important lesson about Autozone's reman starters.
My immobilizer board is garbage so I took it out (it had been unhooked anyway) and everything is running swimmingly. Also serious props for the bumper/headlight access advice! Thank you precopster and vtl!
(Although I'm still slightly questioning my decision to leave the 1990's behind and embrace the P2 Volvos.)
Eric
Eric
2001 XC70, 129,000
2001 XC70, 129,000
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Alarm siren is not an immobilizer. It is just a loud battery-backed buzzer. Immobilizer's function in this car is spread across several computers.
P2 is a good car. Get a working clone of DiCE unit and the car will tell you what's broken.
deepsouth
Gottcha, so my question then becomes: why would having a bad starter installed trigger the "immobilizer, see manual" message? Once I put a working starter in no more immobilizer message and the car runs fine.
2001 XC70, 129,000
2001 XC70, 129,000
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
You can get immobilizer message from key being on for a long time before starter is attempted to be used.
But, it is not a bad idea to drop the lower steering column (3 torx 25 screws up in the torx shaped holes) and then unplug and clean the terminals with contact cleaner spray and then use dielectric grease on them and plug it back in.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Now that's a busted siren module. You will keep having that Alarm message but it goes off after a few minuted driving.
When you get old and crusty enough like me you actually jump starter motors in the parts place before taking them home....glad you got it done!!
- 1781 Views
Last post by 93Regina
- 9 Replies
- 2000 Views
Last post by Ozark Lee
- 791 Views
- 323 Views
- 19 Replies
- 2096 Views
Last post by clutchcinabon
