The ECC is flashing lights on the REC and AC which I know from reading means that there are codes/faults.
Does anyone know if there is a way to get the codes without taking out the ECC? Please let me know if you can.
Thank you.
1996 850 ECC (Electronic Climate Control) light flashing
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Via obdII port,but you need to go to a dealer.
...or you can made yourself a flash code reader,because ECC up to V70 still produce flash codes.
Choice is yours.
Choice is yours.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
I would be disappointed if they don't.They are called "stealership" worldwide for a reason.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
My Autel 802 reader nicely reads Volvo ECC codes. Right now about 200 on ebay or amazon
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I made a little homebrew code reader for the ECC unit. You need a few inexpensive components such as an LED, a switch, a resistor, and some wire. If you're into this type of DIY, it is fun and rewarding! I wrote up the a more complete description of the materials, circuit, use and interpretation of some of the ECC codes here:
https://www.matthewsvolvosite.com/forums ... 43#p251189
Once I learned what the error code was, I fixed one of the components that had failed:
https://www.matthewsvolvosite.com/forums ... 5&p=251432
Good luck!
Good luck!
- 11 Replies
- 6800 Views
Last post by maxi948
- 350 Views
Last post by AlanHMultiV70s
- 20 Replies
- 6197 Views
Last post by RickHaleParker
- 3489 Views
Last post by caliwagon
- 700 Views
Last post by Top Notch
