2009 C70 high beam stays on
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
Timdavis
Year and Model: 2009 C70
Post by Timdavis »
Earlier this week my driver side halogen headlight burned out. I noticed the high beam was on, but dim when the car was running. I assumed this was to compensate for the burned out bulb. I replaced my halogen and the driver side high beam continues to light dimly, even with the main headlight working. Both high beams work, I just can't get the driver side to turn off. Ideas?
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Sound s like corrosion or a short somewhere. Try unplugging, cleaning and reconnecting the bulb connector, and then your headlight relay. Otherwise it could be in your switch or the dimmer stalk.
Current Volvos:
