1998 s70 replacing brake lines, need some advice!
JRev
Year and Model: S70 20V 2.5 1998
Post by JRev »
abscate wrote:Do some research before you buy your flare kit as there are at least three different types of flare fittings I know of - and probably some I don't.
I think i'm just going to go with the safe route as I already screwed this up after doing all the harder aspects, but was just curious as I read a few other threads were people have damaged the union and been told you have to buy a new pipe, yet thought I could save this new pipe as they aren't cheap from Volvo!
Has thanked: 1611 times
Been thanked: 4073 times
I would be perfectly comfortable doing a flare kit. The beauty of this repair is you know immediately if you did it right. Once your flare is sealed, it will shortly rust itself into being sealed forever - as you already know....
JRev
Post by JRev »
abscate wrote:I would be perfectly comfortable doing a flare kit. The beauty of this repair is you know immediately if you did it right. Once your flare is sealed, it will shortly rust itself into being sealed forever - as you already know....
I was looking at this as it works for steel, kunifer and copper lines
http://www.amazon.co.uk/Draper-SAE-Hand ... 8PR7ZA93SJ
JRev
Post by JRev »
Jesus Christ, I'm worse then a woman here with changing my mind but I'm ordering that tool as I bet in the future there will come a time when I have to change other brake lines and this way I can order lengths of brake line, rather then pre made lines from Volvo.
JRev
Post by JRev »
I found that same tool being sold elsewhere cheaper but under a different brand
http://www.ebay.co.uk/itm/151035636166? ... EBIDX%3AIT
A roll of Kunifer pipe
http://www.ebay.co.uk/itm/181251209168? ... EBIDX%3AIT
These brake unions (which I believe are the right ones)
http://www.ebay.co.uk/itm/281102493008? ... EBIDX%3AIT
I can practice a few attempts flaring and I've also ordered some Amalgamating Tape to wrap around points of the pipe as I may cable tie sections which are missing brackets in tight spots.
JRev
Post by JRev »
Just in-case anyone is interested in brake flaring but held off because they assumed it would be too difficult, this video shows how easy it is (with the tool I've purchased). I assume you can get a similar one your side of the pond.
JRev
Post by JRev »
I'm clearly being punished here!.......managed to remove the top caliper bolt which was a 12mm instead of a 13mm, went to remove the bottom caliper bolt and the head is completely rounded off and this time I take no blame as someone before has rounded off that bolt. :cry: :cry: :cry:
You can usually start them with a chisel, then finish them off with vice grips.
Replace of course.
JRev
Post by JRev »
abscate wrote:You can usually start them with a chisel, then finish them off with vice grips.
Replace of course.
Cheers. Hopefully that will work, otherwise I've seen these sockets which grip rounded off bolts.
JRev
Post by JRev »
abscate will likely faint when he reads that I managed to finally install new brake lines/caliper and hose :D :D
