I see lots of post on ETM issues causing a world of issues at all different RPM ranges. I have an issue with my car only having a crazy idle. It runs like a car with a huge lopy cam 500-900 rpm. The car shakes in gear like your head bobbing to music its same in park. My concern with it is I have no codes. Just off idle the cars a dream to drive. No surging no stalling no drop in rpm when slowing down to a stop its idle only. I replaced the spark plugs recently with no changes. I have cleaned the ETM but it really wasn't dirty . My ETM part number is 8644347. I have performed an ETM test in VIDA the sensor max variance is 1.79 so its well in specification. If I had ETM codes it be a no brainer to just replace it but I hate to replace it and that not fix it. The only other concern I have noticed to speak of is the car First thing in the morning is a little slow to want to accelerate like its not building boost after the first shift it drives normal. THe 2 concerns may not be related Any suggestions?
I average 27.2 MPG driving.
If it makes any difference I am running a complete drive train from a 2002 2.4T S60 but I did swap over all sensors injectors and turbo from theT5 car I know injectors and many other sensors are different.
MAF sensor is above 14 at idle.
Short term fuel 1-3 at idle
long term at lower rpm range is 2 max
long term at upper rpm range 2 max
Tried, tune up, cleaned ETM and Mass air flow sensor.. Verified correct cam timing Performed ETM relearn a few times.
2001 S60 T5 Rough idle no codes.
So after lots of tinkering I finally come up with solutions of the car that fixed it. The engine is from a 2002 I swapped or so I thought I swapped everything. The aperture from a 2001 to a 2002, it clocked different so the car saw the cam timing as correct but the reality of it was it was off. Hope it helpes someone.
95 850 n/a 2002 S60 2.4t parted out
96 850T (sold) at 450K miles
98 S70 (sold)
99 S70 T5m (sold)
99 S70 GLT (sold)
01 S60 T5
01 S60 2.4t
06 XC90
98 S70 (sold)
99 S70 T5m (sold)
99 S70 GLT (sold)
01 S60 T5
01 S60 2.4t
06 XC90
- 2554 Views
Last post by chv3ch
- 10 Replies
- 12658 Views
Last post by jonesg
- 2788 Views
Last post by DeadEric
- 561 Views
- 17 Replies
- 6248 Views
Last post by hyperiongate
