1994 850 Outer tie rod replacement part
rebecca8
Year and Model: 1994 850 non-turbo
Post by rebecca8 »
Hello,
I was just wondering what the difference is between a straight OUTER tie rod and the curved one. I know the inner tie rod is straight, but I received a straight outer tie rod as well. I made sure that my car was compatible with the part that was for sale online, and the photo even showed the curved outer tie rod. Of course, when it came, it didn't look the same. I am hoping that it will not be a problem when I take it in. I am only replacing the right side because the left side is fine. I looked up this straight part, and it seems that it is sold for domestic cars. Can I still put it on my volvo, and not have to replace the left side either? Basically, my question is, will it fit? '94 850 base sedan
Thanks.
Rebecca
Has thanked: 311 times
Been thanked: 817 times
If you put up a picture of it we could possibly tell you for sure but it sounds like you were sent the wrong part, and that it won't fit at all. The geometry of the threaded end of the tie rod compared to the ball joint end must be exactly the same as the old one.
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
The tie rod must look like one of these, left and right respectively,
dosbricks
Been thanked: 4 times
Post by dosbricks »
A straight outer tie rod will almost certainly hit the shaft of the sway bar link when the wheel turns inward.
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
keep in mine the inner tie rod is "straight"
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
RussB
Post by RussB »
Here's an inner tie rod,
rebecca8
Post by rebecca8 »
Thanks guys, what you said makes sense, and answered my question. I did take it in, and they replaced what I needed with the right part. I'm still glad I asked on here though because now it is so obvious I was sent the wrong part from the online seller.
Thanks again.
Rebecca
