1998 V70XC Cruise Control Wont Turn On
dew0500
Year and Model: XC70 1998
Post by dew0500 »
Hello,
My '98 v70xc is having trouble with the cruise control, and it has since I bought it a few years ago. But now that I am driving more I would like to try and fix it.
There is absolutely zero response from the car when I do anything cruise related. When I try to turn it on there are no green lights that say "cruise" like most cars to when the cruise control is turned on.
I replaced the fuse, but that is as far as I have gone. Any help is appreciated. Thanks.
My ABS and TRACS lights are on (like a lot of people). Does this affect cruise control?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
dew0500 wrote:My ABS and TRACS lights are on (like a lot of people). Does this affect cruise control?
Yes. If you fix the ABS module then chances are the cruise will work again.
renns
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 6 times
Post by renns »
I've got a V70 AWD, 1998 model, that is likely identical to your XC70 as far as cruise control goes. My ABS/Tracs lights have been on for many months now, and the cruise control works just fine. In these cars, there is no dash light to indicate when you've engaged cruise. I have noticed cruise won't engage properly if the clutch and brake pedals aren't completely up against the stops, depressing the safety switches/valves. If I have trouble with cruise, lifting those pedals with my toe prior to engaging clears that issue. I'd check there first.
On my older 850, I had a cruise problem that ended up being the failure of a small plastic air line under
the battery tray. The cruise actuator is pneumatic (uses air pressure), and this line being chafed through prevented the system from engaging properly.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I had this problem a while ago on a '99 S70. I found a used cruise stalk in a junkyard for about $10, installed it and had working cruise. I'd suspect it is the switch. Try a junkyard replacement.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
